Old 12-03-2017, 11:57 PM   #1
Roof membrane
Hi y'all, I noticed some wrinkling of the roof membrane on my '16 Cat, thoughts?Click image for larger version
ID:	157624Click image for larger version
ID:	157625Click image for larger version
ID:	157626Click image for larger version
ID:	157627Click image for larger version
btf66509 is offline   Reply With Quote
Old 12-04-2017, 07:58 AM   #2
cavie's Avatar
you need a new roof!!!!
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 12-04-2017, 08:15 AM   #3
Old 12-04-2017, 08:24 AM   #4
That looks like more than wrinkles. Looks as if membrain is coming unglued. Need to address ASAP. I would NOT let it get wet ! Water is the death of these things.
Decon Blue is offline   Reply With Quote
Old 12-04-2017, 08:28 AM   #5
cavie's Avatar
Is the roof torn away in the 3rd pic?? No way that is a 2016 roof!
Old 12-04-2017, 08:34 AM   #6
cavie's Avatar
That needs to go straight to Forrest river. Forget about the dealer.
Old 12-04-2017, 08:42 AM   #7
Roof membrane
It's not torn completely away, but the caulking has separated and some went with the membrane. There aren't any places where anything is exposed.......yet.
And not only is it a '16, but I just bought it this May!
Old 12-04-2017, 08:47 AM   #8
Flybob's Avatar
You don't need exposed. The slightest space ( less than the thickness of a piece of paper) will wick water under the membrane. Once it starts it will just get worse. You might get away a new membrane now, but if left uncorrected, you will need a whole new roof if not more.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 12-04-2017, 08:54 AM   #9
Contact Dealer and send Pics to F/R Wildcat Division also,see what F/R says,besides "Take to your Dealer"! This is a Serious Issue! Youroo!!
Old 12-04-2017, 09:12 AM   #10
twohand's Avatar
X2!
Sent from my XT1585 using Forest River Forums mobile app
FROG IL-0076-090
2016 Wildcat 323RBX, 1992 Excel Legacy "guest house"
98 Honda Shadow ACE, 78 Honda CB400A Hondamatic
Nights camped: Ď16 - 24, Ď17 -33, Ď18 - 27, Ď19 - 20
twohand is offline   Reply With Quote
Old 12-04-2017, 09:43 AM   #11
I was afraid this would be the general consensus. I'm two weeks from home and cover. Not to mention that I use this thing 80% of the days for work.
Old 12-04-2017, 12:07 PM   #12
cavie's Avatar
Put a trap over it when parked. You can buy one cheap at Harbor fright. Do not let water on it. Mold inside!!!!!
Old 12-04-2017, 01:37 PM   #13
MilCop4523's Avatar
yep its done. our 2018 toy hauler membrane was cut too short and cannot be stretched to fit under the metal stripping on the sides. I also have 2 strips where it is unglued. Dealership claims 30 to 40 hours labor to correct. manufacturer is quibbling about the time to repair. Dealership says no new roof = no long term warranty. Manufacturer says not covering 30 to 40 hours. had trailer 5 months and its seen 2 days of rain before winter inside stored.
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
Old 12-04-2017, 07:48 PM   #14
Are these the correct contacts?Click image for larger version
Old 12-06-2017, 05:18 AM   #15
Keep use posted, I have the same issue on a '16 and spent several months trying to convince FR and their only response was "it is designed to do that".
corocky1998 is offline   Reply With Quote
Old 12-06-2017, 03:46 PM   #16
cavie's Avatar
that's BS
Old 12-08-2017, 03:46 PM   #17
We have the 29 RKP ( 2018 model purchased in May of 2017 ) the roof does have pockets of air on top but not on the leading edge of the nose like yours. We had ours into Allegiant RV repair ( Forrest River paid ) in Oct. for a repair and I showed them our roof and they claimed it was normal to have some pockets of air and that as along as they didnít grow or move it should be fine ( not sure I believe that ) but that being said mine doesnít look as bad as yours..no pocket is larger than a deck of cards and there are about 9 of these. I would contact Mike at FR he was the one who helped us and got our repairs ( frame issue, fresh water tank issue, slide issue, water in slide when open ) done quickly at no charge. They also paid for two new tires ( due to frame issue ) , and two slide toppers for the slides. My advice is go direct to FR.
Katydid is online now   Reply With Quote
Old 12-08-2017, 07:53 PM   #18
That's my plan Katydid, although I'm still waiting on a reply to my email and/or phone message from Mike. I doubt my "dealer", Camping World, will want to help at all, since they aren't a FR dealer. My rig was part of the inventory they acquired when they bought out the old dealer. Tell me about your water in the slide issue please.
Old 12-08-2017, 08:05 PM   #19
My husband said the Mike at FR is Mike Johnson ( we didnít have luck with Mike Rink as he was moved to some sales position we were told ) My husband said he had to push them, he documented everything with pictures and sent them on first. The slide issue was the wardrobe slide had water that came in through the top and traveled down to the bottom of the slide at the edge and the bottom of the slide was soaked. They agreed ( our suggestion ) to provide toppers to both slides to keep this from happening again. My husband thought the water came in at the edge where the black tape met the white roofing material. The tape was installed incorrectly and came off on one side. I think they know whoever is doing their roof jobs on the line is not doing a very good job because they jumped at providing the toppers as opposed to tearing it apart. Our leak was minimal, so we are trying this first. We bought at Camping World in Richmond,Indiana ( didnít want to but CW bought the Wildcat line and we are told if you want a new one that is the only way to get one now ). We have not gone back to CW for anything. You can mention our names if you talk to Mike. PM me if you want our names. Good Luck...
Old 12-08-2017, 08:11 PM   #20
Thanks, I have your names from a previous PM, I'll do a little name-dropping
roo, roof
