Old 08-07-2016, 11:00 AM   #1
DRM796's Avatar
Roof vent lid
Does anyone know what brand roof vents are installed on a 2012 Wildcat 313re? I do not see any manufacturer from inside the unit. The bedroom cover is cracked and needs replacing.
Ventline?
Yeah I know , I'm being lazy by not getting up on the roof.
2012 Wildcat 313RE
2004 Chevy 2500HD 4D longbed
"Best money we ever wasted"
DRM796 is offline   Reply With Quote
Old 08-08-2016, 10:34 AM   #2
Since no-one has responded, I'll take a shot at this. Not seeing a manufacturers mark on this, you are left with several options: 1) determine what type of vent cap it is. Does it have a hinged lid, curled edge lid, etc. 2) Remove the lid and take it to a RV supply store to see if they cam match it up with a non OEM replacement, which should not be difficult. Replacement lid costs seem to run from about $12 to $25 depending on style and color, with smoke being more expensive. 3) Final option would be to replace entire unit with something equal to, or better than what you have, made a powered fan intake / exhaust vent, although this can be more than you want to spend, or need. Just some ideas and hope it helps. Also, there is a FR rep online now, Wildcat Steve, who may be able to help as he should've the most knowledge and access to older model data.
High Desert is offline   Reply With Quote
Old 08-08-2016, 11:01 AM   #3
DRM796's Avatar
Thanks for the help. I went with option 3 and order a Fan-tastic fan yesterday.
2012 Wildcat 313RE
roo, roof, vent
