Old 09-03-2012, 05:28 AM   #1
amishgirl's Avatar
Roof vents
We need to replace our roof vents on our 2005 Wildcat 29RLBS 5th wheel. Does anyone know what kind of vents the factory installs on this 5th wheel for that year. They are the ones with the fans. They are brittle and 1 on them leaks so bad. Appreciate some advice on this matter.
amishgirl is offline   Reply With Quote
Old 09-03-2012, 06:44 AM   #2
Great Horned Owl's Avatar
Welcome to the forum.
I don't know what kind are on your RV, but it really doesn't make much difference. There are several different brands that will fit in the same space, and are considered interchangeable.
Before you replace the vent, are you really certain that the vent itself is leaking? Much more likely, is the seal where the vent meets the roof is leaking. That is easily repaired without replacing the vent.
As for being brittle, I am not sure I understand. The vents are rigid plastic, and are always somewhat brittle. Are you referring to something other than the body of the vent?
Joel
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
Great Horned Owl is offline   Reply With Quote
Old 09-03-2012, 08:35 AM   #3
amishgirl's Avatar
Roof vents
Thanks for you reply Great Horned Owl, but I think we figured out what to get...we definitely need (2) covers for each of our vents. The entire cover is starting to crack and tiny holes are in it. When I was on the roof I just touched one cover and it broke. They are originals. We took the inside cover trim off in the inside of the camper and there are no water marks or leaks around the outer edges of the opening, therefore, the covers are just not protecting the camper.
I think we ordered the correct ones....they look universal.
Old 09-03-2012, 08:46 AM   #4
While up there replacing the lids,put on some Max Air vent covers also. They will last for a long time,and have many benifits! Youroo!!
Old 09-04-2012, 05:28 AM   #5
amishgirl's Avatar
Roof Vents
Thanks for the info Youroo.....I did see those MAX air vent covers in the RV parts catalog. Will get those on to help protect the roof fan vents. Thanks for your information
Old 09-04-2012, 06:30 AM   #6
TURBS's Avatar
Welcome o the forum !
roof vents, factory, wildcat
