inspect at wall plate
I would suggest that you carefully pull the wall plate inside the unit where you connect your tv (amplifier plate) and visually identify the markings on the cable itself.. that is if none of the cabeling is exposed in any of the storage areas where you could see the same thing much easier. Some times as in my case, it was just easier to install a new external coax connection plate (like cable tv input) in an exterior location where I will have the satellite dish and run RG6 to the location where I have the satellite box inside the unit. When I first looked at my trailer, the cable input line was already RG-6 but my neighbors was RG-59 which he painfully replaced.
Ted
2010 T25KS Wildwood
2006 F-250 SD
STGCM(SW) USN Ret 30 yrs.
