Old 07-01-2015, 03:00 PM   #1
RRG59 or RG6 cable in
I want to install a portable satellite system in my 2015 Wildcat Maxx 27RLS.
I want to know if the exterior cable connector is RG6 cable.
Can you help....
Moejean is offline   Reply With Quote
Old 07-01-2015, 03:28 PM   #2
Adony's Avatar
inspect at wall plate
I would suggest that you carefully pull the wall plate inside the unit where you connect your tv (amplifier plate) and visually identify the markings on the cable itself.. that is if none of the cabeling is exposed in any of the storage areas where you could see the same thing much easier. Some times as in my case, it was just easier to install a new external coax connection plate (like cable tv input) in an exterior location where I will have the satellite dish and run RG6 to the location where I have the satellite box inside the unit. When I first looked at my trailer, the cable input line was already RG-6 but my neighbors was RG-59 which he painfully replaced.
Ted
2010 T25KS Wildwood
2006 F-250 SD
STGCM(SW) USN Ret 30 yrs.
Adony is offline   Reply With Quote
Old 07-01-2015, 03:31 PM   #3
wmtire's Avatar
Can you help....
When I was building my house and running satellite coax myself, I think I recall that RG-59 is not to be used in any satellite installation.
Edit: Better reading:
https://sewelldirect.com/learning-center/rg59-or-rg6
2011 Flagstaff 831 RLBSS
Old 07-01-2015, 03:46 PM   #4
Canadiancrew's Avatar
RG6 is the way to go.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
Canadiancrew is offline   Reply With Quote
Old 07-01-2015, 03:54 PM   #5
DAISY BOYKIN's Avatar
Rg-6 cable
RG-59 wrong for TV input. Always use RG-6 which has a larger diameter center wire for signal to travel on. It gives the least resistance for the TV signal.
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
DAISY BOYKIN is offline   Reply With Quote
Old 07-02-2015, 02:28 PM   #6
BobHanke's Avatar
While RG-59 and RG-6 are both 75 ohm, the RG-59 uses a braided copper wire shield and RG-6 uses an aluminum foil shield and might have a few strands of wire to enhance its grounding ability. RG-59 is more flexible so will stand up to lots of movement. There is one more cable to consider and would probably be best for satellite use....RG-6 Quad-Shield.
BobHanke is offline   Reply With Quote
Old 07-02-2015, 05:20 PM   #7
RG6 is lower loss and is preferable. RG59 will work. I have a house full of it working fine.
Harkerr is offline   Reply With Quote
Old 07-03-2015, 07:29 AM   #8
cpaulsen's Avatar
RG 59 works for sat. tv......been using it for over 10 years with no problem.
cpaulsen is offline   Reply With Quote
Old 07-03-2015, 01:36 PM   #9
It my work but not reccomended. Its a lot higher loss than RG6.
Orval and Yvonne
Old 07-03-2015, 01:42 PM   #10
B and B's Avatar
RG59 can be purchased with same foil shield as RG6. It is has more loss approx 4 db at satellite signals than RG6 but does work in short run situations. I use it at home as I had 2 spools of Belden Foil Shielded RG 59.
The TV Antenna roof connection on your RV is most likely RG 59, mine is.
http://www.net-comber.com/cable-loss.html
B and B
Old 07-03-2015, 02:43 PM   #11
Left Coast
Just pulled 100' of RG6 into trailer to be able to have very short runs of cable outside. Have sat. mount for pin box and ladder....nothing on ground for the fur boys to get tangled up in....now have 3 ways to hook up.
