Old 04-29-2019, 12:09 PM   #1
RV converter
Does anybody know the type of converter that is installed in my 2007 Wildcat 27SE 5th wheel, does it have a smart charger i.e. senses battery charge state and switches on/off as required, also my cooling fan runs all the time even when the AC is not connected.
Paulch is offline   Reply With Quote
Old 04-29-2019, 12:25 PM   #2
Citrus County, Fl.
GL1800Rider's Avatar
From your description of the cooling fan running all the time it sounds like you have a WFCO as the fan is amperage controlled. You can replace it with a Progressive Dynamics which is a 4 stage and you will probably never hear the fan as it is temperature controlled. Your batteries will thank you.
Your converter will sense a low battery and increase the charge as needed. If the fan is running constantly it may be sensing low batteries and perhaps the batteries are due for replacement.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
converter
