Old 09-28-2016, 09:24 AM   #1
Sat TV
I have a 2015 Wildcat 327 ck and there are two Sat connections and one cable connection for TVs, does anyone know if the two Sat connections are one each for each TV? Does the cable go to both TVs? I have a Tale gate for Dish TV but I have not used it with this fiver. Thank You for your imput.
whj469 is offline   Reply With Quote
Old 09-28-2016, 09:44 AM   #2
clr
I also have 3 coax connections two for satellite and one for cable. The satellite coax connections are run directly from the connector on the out side to either the main living room TV or to the bedroom TV. The satellite connectors are home run type arrangement and go directly to only one TV.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 09-28-2016, 06:37 PM   #3
Yep what he said
2016 Wildcat 312BHX
2015 Silverado 3500HD
sugarjohnson is offline   Reply With Quote
