Old 05-28-2018, 09:47 AM   #1
Screen removal
How can I remove screens to wash windows inside
MichaelW is offline   Reply With Quote
Old 05-28-2018, 02:11 PM   #2
It might vary by model, but on ours the screens slide up leaving access to the inner glass
DuckNV is offline   Reply With Quote
Old 05-28-2018, 02:21 PM   #3
AKA: 'tiredTeacher
awellis3's Avatar
If your screens have the plastic tabs at the bottom, you pull them out straight, bottom first. There are spring-fiction clips around the edge that must be depressed by pulling gently out around the edges.
Getting them back in is a royal PITA.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 05-28-2018, 02:30 PM   #4
cavie's Avatar
took mine out once. Never again.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 05-29-2018, 06:53 AM   #5
X2
wing2008 is online now   Reply With Quote
Old 06-03-2018, 04:42 PM   #6
SeventyGTX's Avatar
I can never figure out why they build these things that are not user friendly. Something as simple as taking out a screen to clean the glass should be a no-brainer, not an exercise in futilty. I was just getting ready to pull one of ours out because there is cottonwood seeds between it and the glass, now I'm not sure I will even try.
2016 Wildcat Maxx 262RGX
2016 Ram 2500 Laramie Longhorn 4x4 Cummins 6.7 CCSB Factory Auto-leveling and 5th Wheel Prep w/B&W ball kit, Andersen Ultimate
https://www.forestriverforums.com/attachments/signaturepics/sigpic98816_1.gif
SeventyGTX is offline   Reply With Quote
Old 06-03-2018, 05:22 PM   #7
Everything is a mystery until you actually do it. The first screen I took out by the tabs and reinstalled was a PITA. After that, every screen was easier until now it's a simple process and Liz is happy that both sides of the glass are clean. Myself, I would never wash either side
