Old 12-11-2017, 04:09 PM   #1
Seeking Stabilizer Advice
Our 2008 Wildcat (2 BR) shakes alot when we're set up, and I've been researching the various stabilizer solutions, none of which seem to be amenable to our situation. Our 32' has a manual parking brake in front center (w/electric jacks) right where the mounting bracket would go... so I'd have to get rid of the parking brake in order to mount the stabilizer in front. And my rear jacks are scissors which are not 90į to the caravan, so I don't think stabilizers would work for them. Our caravan wheels are about 6" apart, so I'm not sure X chocks would fit, or if they'd even work (we're currently up on a 2"x6" on one side for leveling). Any advice would be welcome.
Benlevi is offline   Reply With Quote
Old 12-11-2017, 04:24 PM   #2
Could you elaborate on the 'parking brake' you are referring to?
I believe you have a 5th wheel (registry indicates so but you mentioned caravan and I didn't find a caravan model?) and I'm not sure what you are talking about?
Stabilizers like JT's Strong Arms or SteadyFast are somewhat forgiving with 'exact' mounting locations so something should work even with scissor jacks.
X-Chocks should help and work with 6" between the wheels.
They make two sizes. One for wheels closer together and another for wheels farther apart.
You could always use a couple of jacks in the center (once set up) near the front axle to help eliminate some of the shake.
Some suggest a kin pin stabilizer helps but it didn't for me and I gave it away.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 12-11-2017, 04:49 PM   #3
Iím enclosing a pic of the parking brake system; thereís cables going to the back so I imagine it ties into the rear brakes and manually sets them when Iím parked up. Not sure itís necessary, but to install the bracket for front stabilizers it would have to be removed. My 5th wheel is a modified 32QBS where the front bunks have been replaced with a single bed and desk area (very nice setup). I checked the SteadyFast scissors stabilizer installation and they say the jacks must be 90į to the caravan; mine are 45į. I donít think the X-Chocks will make any difference as the swaying is on the ends (when someone in front moves, itís felt at the rear). I thought that the king pin stabilizer would do the trick, especially if I got the extenders so the triangular base would be large... what was your experience with it?
Name:	Front Parking Brake.jpg
Old 12-11-2017, 05:23 PM   #4
cavie's Avatar
A caravan is English/Scotch/Irish for a trailer.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 12-11-2017, 05:47 PM   #5
cavie's Avatar
I use a kingpin stabilizer and x braces and they work fine together. I also take some weight off the tires with two jacks in front of the wheels. The shake is coming from your tires. I do not understand the parking brake? Can you send a picture?? the kingpin stabilizer has a base about 3' across at the ground and a cup goes up to the pin. There is no interference with anything.
Old 12-11-2017, 09:08 PM   #6
Fulltime family RVer
The SteadyFast stabilizers should still work. Just angle them to where you need them.
http://learntorv.com/shake-shake-sha...stabilization/
http://learntorv.com/product-review-...t-stabilizers/
And, Iím sure you can find X-chocks to fit between your wheels. But, truthfully- we donít find a difference when we do and do not use them.
Old 12-11-2017, 09:15 PM   #7
Who Dares, Wins
doc73's Avatar
European trailers have parking brakes built into them.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 12-13-2017, 09:01 AM   #8
onetonford's Avatar
His profile says Alabama? I know in Alstralia they do require a parking brake be installed on any trailer sent over there. actually the parking brake would work like the X chocks but he would be better with something like JT or the like also I have found that scissor jacks put by the axles helped my trailer alot with bounce. rocking front to back I have JT style stablizers with work great. and as far as the lippert stabs I don't use them anymore as they didn't do any good after I put the jacks by the axles I may just remove them and add some more scissors in their place.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 12-23-2017, 02:33 AM   #9
bsmall's Avatar
Hi Onetonford, hope all is well.
I to am thinking about installing scissor style jacks near my axles also. I just havenít crawled underneath to see just where this style will work.
Bill
2008 GMC Duramx-2500HD 4x4 CrewCab
52 Gallon Titan Fuel Tank
Reese18K Signature Series 5th Wheel Hitch With Slider #30085
2010 Wildcat 28RKBS (West Coast Model)
bsmall is offline   Reply With Quote
Old 12-23-2017, 06:32 AM   #10
Mainframe's Avatar
Get a jt style stabilization set up, night and day, you will wish they were included on every camper, x chocks and jts you should be good to go.
2016 Shamrock 23WS
2018 F150 Ecoboost
Mainframe is offline   Reply With Quote
Old 12-23-2017, 10:58 AM   #11
onetonford's Avatar
Have been doing OK have project in shop been working on almost done. Also on mine I had to add a cross brace and drop them 6" so they would contact ground by adding cross brace it helped support under the Fresh water tank which was a bonus also it keeps frame from twisting when you deploy jacks. I can actually lift the wheels off the ground with them as they were rated at 10000 lbs. it shouldn't be a problem.
2011 25 RL Wildcat
Old 12-25-2017, 08:34 PM   #12
bsmall's Avatar
Sounds like a job well done!
I would love to look at how you designed the support member that the jacks attach to.
Bill
Old 12-26-2017, 10:15 PM   #13
onetonford's Avatar
I will try and get some pics taken when I get a chance and post them. I thought I took some but I went thru all my pics and nothing showed up so I will need to get some.
2011 25 RL Wildcat
Old 12-27-2017, 11:22 AM   #14
onetonford's Avatar
cross brace
Ok bsmall here are some pics the end where the jacks are mounted to are 6" I beam pieces with a cut off to make them J shaped the cross pieces are 2 x 2 x .250 square tubing I also tied into the trailer receiver hitch also.
Name:	drivers sid e mount3.JPG
ID:	159077   Click image for larger version
Name:	drivers side mount 2.JPG
ID:	159078   Click image for larger version
Name:	drivers side mount.JPG
ID:	159079   Click image for larger version
Name:	pass sid e 1.JPG
ID:	159080   Click image for larger version
Name:	pass side 2.JPG
Name:	pass side 3.JPG
ID:	159082   Click image for larger version
Name:	pass side 4.JPG
ID:	159083   Click image for larger version
Name:	cross tie to rear hitch.JPG
2011 25 RL Wildcat
Old 12-27-2017, 11:38 AM   #15
2017 Windjammer 3029w
X chocks may help but not enough to be noticable. I am having auto levelers installed in next couple of weeks to hopefully lift enough to stop shake. My trailer came with electric stabilizers but doesn’t give a noticable help either. Reason I am going to levelers.
Nederland, Texas
Dastagg is offline   Reply With Quote
Old 12-27-2017, 06:56 PM   #16
bsmall's Avatar
Thanks oneton for taking the time and posting up the pics of your Center Stabilizer Jacks.
I love the idea, so itíll give me some options when it comes time to install some Center Stabilizers to my trailer.
Bill
Old 12-28-2017, 08:54 AM   #17
onetonford's Avatar
Thanks it helped a lot I hardly even use the old stabs anymore as they don't seem to help any more it is so much more stable.
2011 25 RL Wildcat
