Old 08-04-2019, 12:40 PM   #1
Question Severely corroded propane lines in 2018 model
We have a Forest River 2018 Wildcat 29RLX. On a recent camping trip I was down underneath the camper checking on some things and I noticed that the propane hard pipes/lines were extremely corroded. Is this natural/normal? How often should these lines be replaced? I would imagine that at some point the corrosion is going to cause leaks. We bought our trailer just 18 months ago brand new from Camping World in Richmond, IN. We live in Ohio.
Thank you.
EricInDayton is offline   Reply With Quote
Old 08-04-2019, 12:49 PM   #2
Oaklevel's Avatar
Some rust is fairly normal.
I have never heard of propane lines in a camper needed to be replaced due to corrosion.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 08-04-2019, 12:58 PM   #3
rsdata's Avatar
unless you drive on winter salted roads with your camper, I doubt you have anything to worry about...
ďToo much of anything is bad, but too much good whiskey is barely enough.Ē Ė Mark Twain
2014 Shamrock 183
Old 08-04-2019, 02:13 PM   #4
As in what propane hard lines?... copper tubing or black pipe?
Got a photo?
Days Camped: '16=46 '17=30 '18=51 '19=53
Old 08-04-2019, 03:32 PM   #5
Pipes
The fixed propane pipes are metal. I'm assuming they were once black. I'll try to stop by the storage yard to get a couple pictures to post. The corrosion is far more than I would have expected for an 18 month or so old trailer.
Old 08-04-2019, 04:12 PM   #6
Just as confused as you
Scrapper's Avatar
Have you ever looked at the steel brake and fuel lines running along the frame of your 18 month old car or tv? They will look about the same and you have to remember the tubing is a lot thinner than the 1/2" black pipe. Surface oxidation actually slows the further degradation of the pipe. If the rust starts falling off in chunks or layers then I would be worried. If you are concerned about the pipes disintegrating then you could use a rust converter. https://www.fullgleam.com/car-detail...ust-converter/
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 08-04-2019, 06:18 PM   #7
Iwannacamp's Avatar
If I were worried.... I would get some rust killing primer and get after it. If it is in the open(ie not in standing water) I donít think you have anything to fear.
The place I work sells pipe/valves and fittings. Black pipe (as itís called) is painted with the cheapest paint there is. They will spray to try and ďget it there unrustedĒ. We store our pipe inside(MOST donít) it comes in partially rusted all the time. You can bury black pipe and it will last 20-30-40 years.(I know absence of air)
If you canít chip anything off...you are fine.
2017 Puma 297RLSS
Old 08-05-2019, 02:05 PM   #8
rlh1957's Avatar
Brass and black pipe when exposed to outside weather will quickly get a rusty or corroded appearance. Nothing to worry about unless you are constantly in salt environment. If you operate in a marine or extreme weather area you already know about it. My brother in law has a camper from 2012 and lots of black pipe for LP underneath. It looks really corroded, but it's only surface bloom, we checked every inch to be sure.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
rlh1957 is offline   Reply With Quote
Old 08-05-2019, 08:20 PM   #9
Thank you.
The "main lines" in all campers are generally 1/2" black iron pipe (also known as "gas pipe") Since the wall thickness of the pipe is close to 1/8" and the pressure involved is typically 11"WC (about 1/2 PSI)we're not looking at a rust-through hazard. If you have time when dloing your PM, get a pint can of black Rust Oleum (red label) and paint the pipes which you can see, along with other exposed ferrous metal. Even if rust isn't a big deal in your area, it surely makes the underside of the RV look tidier!
Photo Lab is offline   Reply With Quote
Old 08-05-2019, 08:43 PM   #10
Oaklevel's Avatar
Is that so when it is laying on it's side it will look better ??????
Sorry I couldn't resist..........
1966 Mustang GT
1986 Mustang SVO
propane
