Old 08-12-2014, 12:58 PM   #21
Rugged Brown's Avatar
Originally Posted by Herk7769 View Post
I have to say it is unusual for the frame to flex in the opposite direction of the force applied to it. You would think that with weight on the pin, the gap would close and with weigh off the pin it would open up.
No idea why yours is the opposite...
I don't know how you can make that observation Lou. I would expect that it is flexing in both directions when force is applied. (ie travelling down the road) When the weight is transferred from the pin to the landing gear, the overhang settles and the crack disappears. That's the way I see it.
Terry/Bernadette
Lily the Yorkie
2019 Dodge Ram Sport 1500
2019 FR Vibe 28RL
Rugged Brown is offline   Reply With Quote
Old 08-12-2014, 01:13 PM   #22
wildcat66's Avatar
That is exactly what I meant Rugged Brown. When hooked to truck, the gap opens up between the two metal straps , and when on the ground on the landing legs they close back up!
wildcat66 is offline   Reply With Quote
Old 08-12-2014, 01:37 PM   #23
NELA
Weezer's Avatar
Originally Posted by wildcat66 View Post
The first I heard of WildcatChris was after I posted on this forum! To be honest I don't know how much involvement he had in this issue!
For the record I reached out to WildcatChris in 2 personal messages as he suggested to me in the thread, and never received any response back!
For the record I am not even mentioning the numerous other issues I have experienced with this particular unit. I realize that not all have problems, but when it happens to you it is very aggravating!
Look at his post upthread from this one. He said:
I've been in contact with Jared (one of the best salesmen I work with), Paul, Paul's boss Rob, and my own service staff on your issues. My people have assured me they've got this covered.
So while he may not have corresponded with you directly, he said (and I believe him) that he has been working with your dealer on your behalf.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 08-12-2014, 02:06 PM   #24
Herk7769's Avatar
I was looking at the miter as a hinge. Force up on pin (weight on truck) should close the miter; weight off truck and the front could sag, thus opening the gap in the miter.
Obviously something else is going on.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 08-12-2014, 02:08 PM   #25
Witch Doctor's Avatar
I had the same problem, the solution last year at the Rally was they removed the short screws and installed 41/2" on a angle under the rubber center. It's been a year and no more problems. They did the same to Daisy Boytons unit. The screws where just to short....Good luck and Wildcat is lucky to have Chris on this forum, wish we had a Rockwood rep on this forum.....He'll do you right.... hint, hint, hint FR.
Coachmen M/H
Concord
2018 / 300 DSC
Old 08-12-2014, 02:21 PM   #26
Herk7769's Avatar
They did this to the front of my overhang. I was having trouble keeping caulk in the seam.
Old 08-16-2014, 10:01 AM   #27
JAYCO Representative
Wildcat Chris's Avatar
I'm on the road at a dealer's Open House this weekend, but I will check back in on this when I return!
Wildcat Chris is offline   Reply With Quote
Old 08-19-2014, 08:51 PM   #28
Slympicins's Avatar
Sidewall crack!
We have been looking at a Wildcat model but after some research, I found issues with Lippert's pin box main beam failures. After reading the flexing issues above, it's sounds like these folks are slowly experiencing this. Has anyone had this issue with the main beam failure with newer models? Frankly, it has moved us away from looking at any fifth wheels until we can find Lippert has addressed this major issue.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 08-19-2014, 10:29 PM   #29
Don't all the new Wildcat's use BAL frames?
pbryan is offline   Reply With Quote
Old 08-19-2014, 10:43 PM   #30
Plain Old Member
They do now. Not sure when it started, but I think in the 2014's. Maybe earlier but not sure.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 08-20-2014, 04:52 AM   #31
Slympicins's Avatar
Thin issue wasn't limited to Lippert frames. From what I gather it has to do with engineering lighter frames/pin weight. The pin box area can't support the weight and eventually crumbles.
Chuck and Joanne
Old 08-20-2014, 07:33 AM   #32
I'm going to jump in here with some information even though I don't think it pertains to the original post. Again, I was assured by my team that the issue the original poster had was NOT associated to a frame or structural problem, but rather a sidewall "over routing" issue that may have been incorrectly repaired causing an unsightly crack along the trim.
Frankly, the "Lippert pin box main beam failures" discussion is something I've read about here on this forum (and on other brands' and manufacturers' forums), but have never seen or heard of directly via my service department on anything we've built since I started at Wildcat in the end of 2009. I'm not in any way saying some people aren't experiencing problems -- but I haven't heard of this on a recent Wildcat, Lippert frame or not. My firsthand experience with frame issues is quite limited and we've built literally thousands of Wildcats since I came to Forest River.
Yes. Here are the details:
BAL - Innovative Products for the RV Industry
We are the only fifth wheel manufacturer using this fifth wheel frame across our entire product line, however we are not exclusive. Other products in the industry DO use BAL frames, but not throughout their entire line -- it seems to be floor plan specific.
All Wildcat eXtraLite models have been using it since the beginning of 2013 (so ALL 2014 models). All other Wildcat models followed suit before the end of 2013, further enhanced by the NXG drop-frame (sometimes called a "Z" frame) chassis. All 2015 product uses the BAL frame. I would have to dig a bit deeper to get an exact unit numbers.
I can say this: since starting with the BAL frames last year, we haven't had a single frame-related complaint from our customer base. But our revisions to the Wildcat build also included standard Dexter axles, MOR/ryde suspension and pin box, thicker T-60 high gloss gel-coat exterior walls, and numerous other enhancements "under the skin" or "behind the scenes" so to speak. This collective group of changes, tested multiple times at the Bosch Proving Grounds, gives Wildcat a unique build in the entire industry and thus a unique advantage over our competition.
Old 08-20-2014, 09:31 AM   #33
Slympicins's Avatar
I would like to thank you Wildcat Chris for responding to my question. As one can understand there are user errors which occurs from owners "Overloading" the 5ers, but when you hear of an issue, then Google it and find it's not a specific make of model, its concerning. I will ask you this...I the pin box support less beefed up on a ultra lite vs a regular frame rv?
Chuck and Joanne
Old 08-20-2014, 10:25 AM   #34
This is a great question. Frequently, I am asked why Wildcat's smaller fifth wheel floor plan weights are "so much higher" than similarly sized "ultra lite" brands. The single heaviest part of any RV build is the frame or chassis. The frame build is significantly greater on a Wildcat, in every area, than on an "ultra lite." All Wildcat frame rails measure 10.75" vs. a common 6"-8" on "ultra" light weight frames. The pin box area is also "beefed up," using larger HSLA steel tubes and more cross members. The small floor plans are built exactly like the large floor plans!
This is NOT to say that the "ultra lite" fifth wheels on the market today are not built well or strongly enough, but they ARE built specifically for weight. Building specifically for weight means cutting weight wherever possible, usually starting at the heaviest items first.
Old 08-20-2014, 03:00 PM   #35
Plain Old Member
Chris, figured I'd ask this while you're on here. Hopefully not hijacking too bad. An all too common problem with several brands is the slide floors. The darco fabric wears and tears, sometimes where the floor is secured up through the floor, the water can wick into those holes, some just barely coat the edge of the wood on the slide floor ends with paint when darco is not used, and in the complaint list goes. Several threads on this issue, across many FR products, and non-FR products.
Rockwood / Flagstaff seems to be one of the few that use the 90 degree plastic glide on the slide floor ends. They tuck under the slide end wall trim and go several inches under the slide. This solves the potential water wick problem and the wearing darco problem. Not sure the make of those, but we had the same thing installed under our slides due to same potential issue. Ours are made by Majestic Formed Plastics.
I'm not real familiar with the specifics of a wildcat slide floor, but do know that I have seen several pre-2014's with this issue. What is Wildcat doing now? Do they have the glides installed, or do they have a better coated slide floor? Doesn't seem too many manufacturers want to change to a better set up.
Although Wildcat doesn't fit our needs, we do keep up with all makes and models to see where everybody's headed. Between the different frame, axles and using a MorRyde pin box, it looks like y'all are headed in the right direction.
Sent by ME
Old 08-21-2014, 08:39 AM   #36
So as not to hijack this thread any further, I've responded here:
http://www.forestriverforums.com/for...tml#post684235
