Old 06-23-2015, 08:08 PM   #11
asquared
I get nothing when on my next trip to the trailer I'll have to check the wiring. The rodents haven't chewed anything in the landing compartment where the pump is I'll have to check continuity and voltage. thanks
Nicster21 is offline   Reply With Quote
Old 06-23-2015, 08:13 PM   #12
mark0224's Avatar
Originally Posted by asquared View Post
Do you get any clicking noise or just silence and no movement? I would double check connections and make sure rodents haven't chewed through any wires.
I was thinking the same thing Rodent chewed through a wire being stored in a barn there usually are mice in barns. I had my boat motor in my garage and one chewed through the gas line from the pump to the carb. If that won't stop one then a wire if fair game.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 06-24-2015, 11:48 AM   #13
Thanks everyone
Like I said I'll check next month when I go back to the trailer. I appreciate all the help and when I find out what the problem is I'll report it to this thread.
Old 06-24-2015, 12:04 PM   #14
Possibly one of the little furry critters took a liking to your wiring?
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is online now   Reply With Quote
Old 06-24-2015, 12:15 PM   #15
have no idea whether or not your 5th wheel is wired significantly different from our travel trailer, but our slide has a direct run to batt, thru its own breaker/fuse, and does not go thru the main CB panel/converter -- recommend using your volt-ohm meter to check voltage level at slide system -- if batt is not fully there (slide motor, etc, does have a minimum voltage needed to operate), trace the wire to check for high resistance shorts to ground -- good luck --
Wanderers thru Wonders
Flagstaff 21FBRS led by F150 5.4
Sun & Moon, direct us...
don1 is offline   Reply With Quote
Old 06-24-2015, 01:05 PM   #16
Is there power at the switch?
How about the ground?
2016 Vibe 268RKS
2015 Chev 2500HD
Mewcasa is offline   Reply With Quote
Old 06-24-2015, 03:41 PM   #17
Mine has a fuse right off the battery. Might check
Harkerr is offline   Reply With Quote
Old 06-24-2015, 08:47 PM   #18
mikes86gn's Avatar
My old Wildcat TT had two auto reset breakers just on the inside of the tongue, right side, inline with the side of the battery box. There was a rubber flap covering them. The one for my slide corroded and the slide quit working. Replaced the breaker and all was good.
2012 Silverado 2500HD 6.0 Gas 4.10 gears
1986 Buick Grand National 4500 Actual Miles
2015 Crusader 28RL
Days camped 2014 33 . 2015 42. 2016 38. 2017 35.
mikes86gn is offline   Reply With Quote
Old 06-24-2015, 09:00 PM   #19
Crockett's Avatar
Check to see if the battery got swapped and a cable just got left off...like the pump cable. seen that happen a lot...
Crockett is offline   Reply With Quote
Old 06-25-2015, 05:21 AM   #20
Had a slide problem with my 2015 Rockport. Checked all of the interior fuses and they were ok. The fuse on my camper was under the battery under the frame that connects to my tow vehicle. The 30A fuse was blown. Replaced it and the slide works normally. Hope this helps.
davidinstlouis is offline   Reply With Quote
slide, slide out
