Old 07-25-2016, 11:50 AM   #1
Slides & Battery life
Hello Wildcats
Wife and I just returned from a 800 mile maiden trip with our new 29.5 RSX Happy to report no issues, ? Thinking on our next trip to Ohio in Aug and as a over niter staying in a Walmart/Truck stop, Would it be OK to operate the slides on the battery? Or would this create to much of a drain and find myself in trouble the next morning? I assume the battery gets charged while its plugged in to the vehicle while being towed, Being parked and plugged in would the unit also be fed thru the truck battery's.
Ken
wing2008 is offline   Reply With Quote
Old 07-25-2016, 04:19 PM   #2
Learjet's Avatar
Depends on your make/model/yr and if the truck is factory or customer installed 7-way.
No your Trailer battery should not get drained by just a quick use for the slides. You could always run the truck while operating the slides to help, assuming your truck is set up to provide power while running.
FYI...both my Ford factory setup and my old Nissan Titan had switched power to the 7-way.
-2013 Ford F250 XLT 2wd Crew Cab 6.2 with 3.73
-2015 Wildcat 317RL
-B&W Patriot 18k, MorRyde, Timbrens
Learjet is offline   Reply With Quote
Old 07-25-2016, 05:25 PM   #3
Thanks for your reply Lear, The truck is a 2016 250 diesel Ram, Factory electrical set up.
Old 07-25-2016, 07:07 PM   #4
5er_tom's Avatar
Yup. We have moved the slides on battery several times. No problem.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2012 Ford F-250, 4x4, 6.7 Liter Diesel
5er_tom is offline   Reply With Quote
Old 07-25-2016, 08:27 PM   #5
Tom thanks for your reply,By the way did your 29.5 come with a Furron built in rear camera installed? Ours did and it works off and on and constantly shows a red square flashing on the screen, I have adjusted the antenna as the instruction suggest with no success I have the model with the #48 in the serial #, ...............Ken
Old 07-26-2016, 08:24 AM   #6
5er_tom's Avatar
Yes, came with the camera. It worked on and off. The dealer replaced it under warranty. Replaced both the camera and the display unit. It worked great all the home from the dealer (35 miles) and has not worked since. Go figure!
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
Old 07-26-2016, 02:35 PM   #7
Blog: RVroadtripper.com
hbillsmith's Avatar
I'd give FURRION customer support a call. If they're suggestions don't help, they will just send you a completely new unit. The swap out is very easy and only requires a small phillips screw driver.
FURRION is in Elkhart and their phone number is Toll free: 1.888.354.5792
Maxxis 16" E; Ride Rite AirBags w/AirLift 1 wireless compr; Adv.Folding 4 Cover
Andersen Ultimate II Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball
LCI Ground Control 3.0 4pt + 2pt Elec.Rear stabilizers; 3 Slidecovers; 10ft. Portabote
6000# Dexters; mor/Ryde CRE3000 w/HD Wetbolts; King Dish Tailgater; 5hp Outboard
Dual A/C; Furrion 48 Rear Camera; Champion 3100 Inverter w/Extended Run
hbillsmith is offline   Reply With Quote
Old 07-26-2016, 07:17 PM   #8
Thanks for the reply's, I'll them a call.
Old 07-26-2016, 09:34 PM   #9
My slides will not operate while my truck is running. I assume it is a safety feature so they don't accidentally slide open while driving on the open road.
__________________________________________________ ______________
2013 Sunseeker 3170ds
bobbrown is offline   Reply With Quote
battery, slide, slide out
