Old 07-13-2013, 10:25 PM   #11
Newbie.
monte0999's Avatar
Something else I noticed was that when I try to do the Parking light trick by inserting the fuse into the truck power cord adapter, it doesn't work. .....wondering if its related somehow to this?
2013 344 QBOK
2011 F250 4x4 Supercrew Diesel
monte0999 is offline   Reply With Quote
Old 07-18-2013, 06:36 PM   #12
Newbie.
monte0999's Avatar
Note to guys with hydraulic slides. There is a slide motor controller box called a "Dual Motor Synchronous Velocity Slide Controller" mine is in drivers side storage compartment attached to front wall.
Simply unplug the slide motors from the box and manually push slides in or out. When finished, plug motors back in an that will act as a brake.
Easy way to get out of a jam.
2013 344 QBOK
