Old 07-13-2013, 10:23 AM   #1
Newbie.
monte0999's Avatar
Slides have no power
Trying to hook up to move to next site. Plugged into 50 amp outlet, no breakers tripped, ac works, slides acting like running out of juice. Almost as if battery is running them and its dead.
What am I missing fellas?
Added battery pack to battery and turned it on to see and still nothing.
2013 344 QBOK
2011 F250 4x4 Supercrew Diesel
monte0999 is offline   Reply With Quote
Old 07-13-2013, 10:24 AM   #2
Newbie.
monte0999's Avatar
I got bedroom slide in, noticed she was moving slow. Rear slides won't budge.
2013 344 QBOK
Old 07-13-2013, 12:16 PM   #3
Newbie.
monte0999's Avatar
Battery is dead. That is problem.
For some reason it won't accept a charge when trailer plugged into wall socket at home. Ill buy a new battery but need to figure out why system won't charge battery.
I had to use jumper cables to move slides in and out.
2013 344 QBOK
Old 07-13-2013, 12:31 PM   #4
caper's Avatar
Do any of your 12v lights work? You might have a bad converter. Do you have a battery disconnect?
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 07-13-2013, 12:59 PM   #5
Herk7769's Avatar
Check also the circuit protection located near the battery that connects the converter to the battery.
Looks like this. See if button on the side is popped...
HAM CALLSIGN - KC3FFW
Old 07-13-2013, 04:45 PM   #6
Newbie.
monte0999's Avatar
This is what I see. (Nice sawdust pile left over from factory)
No button that I can find.
2013 344 QBOK
Old 07-13-2013, 05:14 PM   #7
TURBS's Avatar
Just a quick thought....
Did you by chance un hook battery then hook it back up recently ?
The converter has reverse battery protection and if the battery was hooked up backwards it'll blow a fuse and not charge. fuse might be blown regardless .
WFCO converter ?
Old 07-13-2013, 05:39 PM   #8
Newbie.
monte0999's Avatar
Battery came from dealer disconnected. Or loosely connected. Had same symptoms that first night in my driveway until I attached the battery fully and added a charger.
Battery just will not hold a charge. Hooked up red to +ve and black to -ve. So hooked up properly.
5 amp fuse in there is good. Just tested it.
2013 344 QBOK
Old 07-13-2013, 05:47 PM   #9
caper's Avatar
When plugged into 120v do you have 12v lights?
Terry and Janet
2007 Ford F150
Old 07-13-2013, 07:28 PM   #10
Newbie.
monte0999's Avatar
Yes. Everything works but the slide motors. Acting like they're drawing only from battery.
2013 344 QBOK
