Old 05-12-2016, 05:54 AM   #1
RSchleder's Avatar
Slippery Brakes
While recently greasing my wheel bearings on my Wildcat MAXX, I found one of the seals had leaked and there is grease on the brake magnet and the drum surface it contacts with. Can I simply (carefully) clean the drum surface and the magnet with brake cleaner or (?) and reassemble? Is not, what process should I use?
Thanks in advance for any info, Ron
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 05-12-2016, 09:43 AM   #2
Learjet's Avatar
brakes pads need to be changed if contaminated.
No sure about magnet, but I would guess you could clean it with brake cleaner and yes for the drum it self.
Did you pump grease into the axle with the "EZ lube" ??
-2017 Ram Cummins, Aisin DRW 3.73, 4x4
-2015 Wildcat 317RL
-B&W Companion , MorRyde pinbox
Learjet is offline   Reply With Quote
Old 05-12-2016, 10:51 AM   #3
RSchleder's Avatar
Yes, EZ lub zerk was greased a few months ago.
30 years RV'ing
11 different RV's
Old 05-12-2016, 11:15 AM   #4
Yes, brake cleaner will do ya.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 05-12-2016, 11:17 AM   #5
Best to use the EZ Lube when it is warm outside.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 05-12-2016, 11:42 AM   #6
Restcure's Avatar
I've also heard that you should spin the wheel as you're pumping in the fresh grease... otherwise the rear seal can fail.
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
Restcure is offline   Reply With Quote
Old 05-12-2016, 03:07 PM   #7
RSchleder's Avatar
Thanks all! Took the wheel apart, cleaned everything with brake cleaner, reassembled so all should be good to go. I appreciate everyone taking the time to provide the brake knowledge. All the best!!
30 years RV'ing
11 different RV's
Old 05-12-2016, 06:33 PM   #8
Learjet's Avatar
There lies the problem, had the same thing happen to me. Better to be safe and not use the EZ lub. JMHO
-2015 Wildcat 317RL
Old 05-12-2016, 06:40 PM   #9
RSchleder's Avatar
I couldn't agree more. As the old saying goes " Fool me once, shame on you", well you know the rest!
30 years RV'ing
11 different RV's
Old 05-12-2016, 07:33 PM   #10
Yea JD you are supposed to slowly spin the tire as you slowly pump the grease. I have done this several times without issue.
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
brakes
