Old 04-23-2016, 11:46 PM   #1
cavie's Avatar
snow load
This new to rv living guy from Florida needs to know what to expect from snow on the roof. Is snow load an issue?? Unit will be in MA and I'll be in Florida.
Old 04-24-2016, 12:13 AM   #2
sorry read it wrong. This time of year you really won't have to worry about it. Are you talking next winter?
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 04-24-2016, 01:32 AM   #3
Witch Doctor's Avatar
It's hard to say, I know RV lots don't clean there roofs on units for sale, but alot of members said they clean what they can safely at home. Snow can get pretty heavy. If snow is a problem up there I would bet someone has a business to clean them off, you might check that. You might call a dealer up there and ask that question....good luck..I get about 6" here at a time but it melts in a couple of days so I don't do anything, I sure wouldn't be walking around on the roof cleaning it...May be someone from up there will let you know how they handle it...
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 04-24-2016, 01:48 AM   #4
Phat Phrog Stunt Crew
elind's Avatar
Will the snow be to heavy on the tires and the axles? Last winter I had a couple of feet of snow shoveled off the roof before I left for Arizona. I thought I would be overloaded going down the road.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 04-24-2016, 01:53 AM   #5
cavie's Avatar
unit is a 27RK wildcat. Set up in a campground on a seasonal lot. park closed for 6 months in the winter. Slide will be closed. Might buy a cover.
Old 04-24-2016, 02:29 AM   #6
For sure I would buy a cover, if nothning else for a barrier to protect your ac. And vents. You might also look for a covered RV storage area and move it there for the winter and then move it back to your spot in spring and Elina your right it would cause you to be over for your axles and tires, snow is heavy and I don't know what the load an RV roof is built to, good question for FR.
Sent from my SM-N920V using Tapatalk
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-24-2016, 10:52 AM   #7
Our camper is on a seasonal site in Wisconsin. We do get our fair share of snow and I have never gone up to shovel/sweep the roof off. Never had a problem.
snow
