Old 06-01-2015, 10:23 AM   #1
Stabilizer jack quit
I have a 2014 Wildcat Max 27rls with the powered stabilizer jacks on the front and rear. The front stabilizer motor quit while retracting the jacks. They won't work with the remote or switch mounted on the trailer. I was able to retract them manually, so they move freely. I can't seem to find the fuse to the motor. Any ideas as to where it is? Or do I have a bigger issue. The motor for the back jacks works fine.
lddoty is offline   Reply With Quote
Old 06-01-2015, 06:10 PM   #2
wwalker2984's Avatar
On mine the fuse was right no top of the motor it was a 30 amp fuse and it wood blow a lot and I replaced it with a auto reset breaker works Great now
wwalker2984 is online now   Reply With Quote
Old 06-01-2015, 06:50 PM   #3
davel1971's Avatar
could be a circuit breaker mounted near the switch. I've had them corrode since they are out in the elements
David & Lynn
Old 08-07-2015, 02:36 PM   #4
We just purchased a 27RLS Wildcat Maxx and have an interesting stabilizer problem. The jacks quit working when using the manual switches but will work with the remote. It's a warranty item but I want understand and know the location of the remote controller box. Our unit has elec. awning, jacks, lights. so it must have a relay panel. Anyone know where it may be located?
Burk
Burk is offline   Reply With Quote
Old 08-07-2015, 02:44 PM   #5
C/B location, Relay controler remote location?
On our new 2015 27RLS the circuit breakers are located on the frame by the switches. I have a problem with our jacks not working with the manual switches but will work with the remote? Do any of you know where the controller for the remote functions is located?
Burk
Old 06-15-2016, 02:42 PM   #6
Did you correct the problem with the manual stablizer switches.I have the exact problem that just cropped up. Remote works but manual switch will not. Switch is good.
wwc1921 is offline   Reply With Quote
Old 06-21-2016, 09:37 AM   #7
I have 2016 26FBS my rear jacks switches works some time manual sometime also. Also looking for a fix goes to the dealer and works fine????
Ken
junket is offline   Reply With Quote
Old 06-21-2016, 08:04 PM   #8
cavie's Avatar
clean switch contacs.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Newley Retired.
Old 06-21-2016, 08:43 PM   #9
The switch appears to be a sealed epoxy unit the wires with a 8" pigtail into a 4 way junction box.
Just spray contact cleaner the face??
Ken
Old 06-21-2016, 08:50 PM   #10
cavie's Avatar
It's worth a shot. Also look for the rely that the switch controls. Full power won't go thru the switch..
Newley Retired.
