Old 02-22-2018, 06:49 PM   #1
Steadyfast
Is it worth the money! And does it take the wobble out of my fifth wheel?
MichaelW is offline   Reply With Quote
Old 02-22-2018, 06:51 PM   #2
It definitely takes the majority of the wobble out. Nothing will make your RV wobble free unless you set it on blocks
Only you know if that is worth the $$$ to you
Old 02-22-2018, 07:15 PM   #3
Fulltime family RVer
Yes, worth the money.
Takes a lot of wobble out but nothing is 100%.
I definitely like it better than the JT StrongArm knockoffs I had before.
Old 02-22-2018, 07:30 PM   #4
Casey & Carolyn
Casey r's Avatar
I have a set of JT Strongarms front and rear use them with X-chocks. Big difference than without.
I believe the JT's are comparable to the Steadfast.
Casey and Carolyn Rice
Las Vegas Nv
2017 Prime Time Crusader Lite 29 RS
2018 Ram 3500 4x4 CC Cummins Powered
Casey r is offline   Reply With Quote
Old 02-22-2018, 09:05 PM   #5
Yes worth the money.
Days Camped: '16=46 '17=30 '18=51 '19=50
