The Leak Continues
Hi friends,
I need some joined problem-solving brain power. We have a 2013 Wildcat 337FB with a leak in the rear corner. The leak is near a slide, so our first thought was seal malfunction. We had the seals replaced by the dealer, but the leak continues. It does appear that it only leaks when the unit is closed (though I'm not entirely certain this is the case.) I have attached photos. The inside photos are with the slide slightly retracted. Also, the previous owner did hook the rear of the unit on something, as you can see from the photos, but it was repaired at the dealer. So, I do not believe this to be the culprit, especially since the problem presents only when closed. Anyone else had this problem before?
