Thermostat?
Duo-therm model #3107612-008. Rv is a 2007 Wildcat F29 5th wheel. not sure if the thermostat is bad. Furnace will not kick on at all. AC unit will click when I put it to cool and that is all. No heat and no air. All I get is a click. Doesn't matter what temp I set it to either. no combinations work i.e.- cool/fan on/hi, cool/auto/hi, heat/fan on/l. Have checked breakers and flipped them multiple times. Checked all fuses and checked every outlet including GFCI-all good
