Old 10-11-2016, 08:54 PM   #1
RSchleder's Avatar
This one puzzles me?
My son has a 2010 21' Rockwood Mini. We winterized it on Sunday and I was impressed with the Winterizing Hose Connection on the outside of the trailer. This connection allows a standard hose to be connected and the cut end of a 4' hose (cut from an old hose) when placed in a gal jug of antifreeze, draw the solution into the system. There is, of course, a valve to turn in the pump area which switches the suction from the fresh water tank to the Winterizing Hose Connection.
Now the reason this "puzzles me" is not that this exists and works perfectly. No, I'm puzzled because my 2016, 33' RKX Wildcat MAXX, which cost twice as much as his Rockwood, does not have this feature. There is absolutely no provision for getting antifreeze into the system other that adding 2-3 gal to the fresh water tank OR, disconnecting the inlet hose from the fresh water tank to the water pump and attaching a home made replacement hose that can then be run to a gal jug of antifreeze.
I mean, give me a break, this can't be a $25 (parts/labor/overhead) accessory if installed during the production phase. This is my second Wildcat Maxx and the first one was void of this connector also. So, after owning 2 Wildcat Maxx TT's during the past 3 years, I've found the first thing that really puzzles and disappoints me!!!
Days camping (2016)----181 days
Days camping (2017) --- 52 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
12 different RV's
RSchleder is offline   Reply With Quote
Old 10-12-2016, 02:05 AM   #2
2007 WildCat 32QBBS
05CrewDually's Avatar
12 bucks and you'll be up to speed.
https://www.amazon.com/dp/B0006JJ588..._faE.xb4TS6B6R
05CrewDually is offline   Reply With Quote
Old 10-12-2016, 04:45 AM   #3
Oaklevel's Avatar
Mine is not a Wildcat but I have seen several similar setups to above from the factory located at the out feed end of the water pump. mine is under the kitchen cabinets.
2005 Dodge 3500 Cummins
2013 Puma Unleashed 356 QLB
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 10-12-2016, 06:40 AM   #4
jeff
jeff64's Avatar
Most of what I've seen may have a selector valve at the inlet to the water pump with a piece of vinyl tubing attached which goes into the AF jug
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 10-12-2016, 06:57 AM   #5
wmtire's Avatar
X2, as my 2011 Flagstaff came with the clear hose in a cabinet drawer. You have to access the water pump in mine thru a fake cabinet door underneath the television.
2011 Flagstaff 831 RLBSS
At the end of the day, it's dark.
Old 10-12-2016, 07:13 AM   #6
Flybob's Avatar
You may have to the bypass valve, but it is just not as easily accessible. Look at the input to the physical water pump ( might be behind a panel).
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 10-12-2016, 07:24 AM   #7
RSchleder's Avatar
Thanks folks--believe me I have looked, I even replaced the faulty water pump a year ago. There is no valve, no hose, nothing on or near the pump! I know, unbelievable but true, thus my disappointment!!!!
30 years RV'ing
12 different RV's
Old 10-12-2016, 08:06 AM   #8
RSchleder's Avatar
Thanks 05CrewDually. Ordered the kit this morning. i appreciate the help and link!
30 years RV'ing
12 different RV's
Old 10-12-2016, 08:40 AM   #9
This "Kit" will reduce your Suction input by over 50%! This will Only effect Members who run on "Pump"! The Valve diverter reduces flow from "Tank and A/F" position! Here are Pics! Any Pump suction side is "Larger than the Output side" Except when using this Valve Kit! Youroo!!
ID:	122770   Click image for larger version
Old 10-12-2016, 11:35 AM   #10
2007 WildCat 32QBBS
Works fine here. Been on my Wildcat for years. Plenty of flow for the toilet and all. Pump cycles on and off just like normal. That tells me it has enough flow if while the water is on the pump shuts on and off.
