Old 06-01-2017, 06:09 PM   #1
duradiesel's Avatar
Tire damage
I am wondering if i can get the right side lower sheet metal panel between steps & the slide from Forest River & who to contact. Had a blow out on the rear tire.
2006 GMC Duramax Extcab LB
2012 Wildcat Sterling 32RL
duradiesel is offline   Reply With Quote
Old 06-05-2017, 10:44 AM   #2
Factory Representative
Wildcat Steve's Avatar
Contact your local dealer and let them know what parts you will be needing. They will then get in touch with the factory and order the parts. Unfortunately the factory is not set up to sell parts direct to the retail customer at this time.
Thanks,
Wildcat Steve
Wildcat Steve is offline   Reply With Quote
Old 06-05-2017, 12:15 PM   #3
duradiesel's Avatar
Thanks Wildcat Steve
Old 06-06-2017, 12:32 AM   #4
bsmall's Avatar
I can feel your pain on the damage caused by the blowout you had.
Had a tire blow and did about 4500.00 in damage to the right side above the tires.
I ended up buying 4 Michelin XPS LT tires.
I hope you're back on the road soon.
Bill
2008 GMC Duramx-2500HD 4x4 CrewCab
52 Gallon Titan Fuel Tank
Reese18K Signature Series 5th Wheel Hitch With Slider #30085
2010 Wildcat 28RKBS (West Coast Model)
bsmall is offline   Reply With Quote
tire
