10-28-2016, 12:52 PM
Tire load rating vs trailer weight
so I need some help, My Wildcat came with 205/75R15 load range C tires, the tires state they hold 1820 lbs, adding all four tires I get 7280 lbs. My trailer GVWR 7620. To me this is a deficit of 340 lbs, the manufacture says these tires are certified by NTSB to be correct for the vehicle. An I supposed to subtract the tongue weight from my weight calculations ?
2017 -255 RLX Wildcat Maxx Lite
2013 F150 3.6L super crew
10-28-2016, 12:54 PM
Yes subtract tongue weight.....
Fonzie
10-28-2016, 02:15 PM
Thanks, guess that puts me in the green as far as weight goes, just barely
10-28-2016, 02:29 PM
Correctly loaded, you should have a MINIMUM of 10% of the trailer weight as tongue weight. Take this to the maximum the trailer should ever weigh (GVWR), and you should have 762 lbs of tongue weight and 6,858 lbs on the axle. This should give you 422 lbs minimum of buffer. By not maxing out to GVWR or going more than 10% tongue weight and your buffer increases.
10-28-2016, 03:19 PM
Thanks, that doesn't seem like a great safety margin judging by some of the threads I have read, but it gets FR off the hook.
10-28-2016, 04:33 PM
And that exact reason is why I upgraded to D rated after I did the math on my unit.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
10-28-2016, 04:39 PM
The tongue weight on a 5er should be between 17 and 25% of the gross weight, that's how they get by with a "C" rated tire. If I were the OP I would move up to the "D" or even "E" if the rim can hold the the "E" PSI...
Coachmen M/H
Concord
2018 / 300 DSC
10-28-2016, 07:13 PM
Learning a lot as I go...
Yup, *just* enough. That is how they design and build them. Violently agreed that a bit of safety margin would be appreciated.
2015 Rockwood 2604WS (sold as 2016)
2014 Ford F-150 Ecoboost
10-28-2016, 07:46 PM
Mine had C rated tires from the factory. After about a year I upgraded to load range E tires and added a TPMS system. MUCH less stress and worry.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2006 model year Border Collie
10-28-2016, 08:44 PM
What is TMPS ? I plan on upgrading at least to "D" if not E.
2017 255rlx Wildcat Maxx lite
10-28-2016, 09:58 PM
Tire Pressure Monitoring System
10-29-2016, 12:46 PM
I upgraded my E rated to G614's with less than 1000 miles on them. Peace of mind and our crappy pot holed roads made it a no brainer for me.
Just make sure your rims are rated for the increase psi. I was lucky and mine were rated for the G rating. This surprises me because FR and others are always looking to save a few bucks. Maybe they know many people are going to upgrade and did us a favor ?
Bill
2016 Forest River 3250 Cardinal
2016 RAM 2500 Longhorn
Previously: 36' Country Coach
10-29-2016, 01:55 PM
Yes- what he said. Many c rated wheels are rated to 60 psi. I just run my d tires at 60 psi.
10-29-2016, 04:38 PM
Tire pressure monitoring system I run an eez go system on my Truck and trailer. (Chevy 2500 hd, Crudader 315). just saved me when I had one of my truck tires going low. Bad valve stem. Saved a 200 dollar tire and let me know so I didn't have to change it on the highway. 15 bucks to replace the valve stem and down the road we went.
10-30-2016, 11:54 AM
How do you know what the rims are rated for, as far as tire size and PSI???
Dave & Elaine
Brookfield, WI
2021 Rockwood, 2509s, pulled by a 2020 Ford F150 XLT, Super Cab, 3.5L Eco Boost, with 3.55 axle. Electric 10-speed auto trans w/tow mod. Heavy Duty Tow package & integrated trailer brake, 11,700 lb. tow capacity, payload is 1916 lbs. and 145” wheel base. Equalizer 4 point W/D hitch.
10-30-2016, 12:12 PM
It should be stamped on the inside of your rims. My rims were stamped 3750 which is good for a G rated tire even though FR only put E rated tires.
Goodyear RV Tires – Tire Selector
Bill
10-30-2016, 02:19 PM
If you have these rims on your Rockwood here it is, most use this rim also flagstaff. Most of the time as mentioned the PSI is stamped on the inside.
Coachmen M/H
Concord
2018 / 300 DSC
10-30-2016, 02:39 PM
They never install the correct rated tire for the units . all come maxed out from the factory . TW works good on paper but not in the real world. out on the road where there will be times when all the weight of the TT is on it's own tires . always go with a better Rated tire . if you have C then D but E will work . your rim should have a weight stamp on the inside rim indicating max weight for the wheel . get a tire to match max weight and fill the tire manufactures max psi . on my unit it came with D rated not even close to carrying the full weight of my TH loaded . so i went up to E now i have almost a 2000lbs margin of safety
10-30-2016, 05:00 PM
I went from LRCs to LRDs Maxxis tires and run a TPMS. I researched going to LREs but after discussing with the tire expert on this forum he said I'd be better off running LRDs because at the weight of my rig the wheel/axle combo is not really suited for the LREs. The weight of the trailer would be running the LREs under-inflated and that is bad, whereas running the LRDs more towards max air pressure.
My rig is light @ ~9klbs, so running the LRDs is fine.
I originally thought going with the highest rated tire would be the best choice, just a few bucks more, but I found out otherwise. Your mileage may differ...
2015 Rockwood 8289WS
2003 Dodge Cummins w/Banks 3:73
10-30-2016, 05:21 PM
Why would the LRE's be run under inflated . I've seen weight ratings on rims but never psi
