Old 11-30-2013, 09:32 AM   #21
jevanb's Avatar
Originally Posted by Davidceder View Post
The Pullrite plate is set with 4 allen set screws. (no more welding) Spec says use some red loctite. I put on very little loctite in case I ever need to remove the plate, which I have not yet. No adjustments necessary, just set the screws. Should take a minute to remove or install. I love the Pullrite, no thinking about it..........Don't even know its sliding all the time.
not all adapters have 4 allen screws . mine is attached with 1 screw and a lock nut, I would never use red locktite, because I remove mine, if i left it on and wanted to remove in the future I would use blue locktite. the other screws in the picture are holding on 1/4 plate aluminum that keeps the adapter from moving side to side
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
