Old 06-27-2019, 11:21 AM   #1
Toilet gasket (for the bowl)
I have a 2016 Wildcat maxx 312bhx. Does anybody know what model toilet is in the 5th wheel? My toilet doesn't hold water for barely any time so I'm going to replace the gasket. I'm trying to reach out before heading to the storage spot to find out so I order the correct one. Thanks!
Cidewayz is offline   Reply With Quote
Old 06-27-2019, 11:46 AM   #2
PPST Wannabe
kenandterry's Avatar
RV manufacturers change suppliers of various components all the time.
The only way to be sure is have a look at your own toilet. Even another Wildcat may have a different make and model.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is online now   Reply With Quote
Old 06-27-2019, 11:54 AM   #3
Look for a sticker on the back of the toilet. May need a mirror to see it or just pull the toilet up- easy to do and you'll want to do that anyway. Note that any time a toilet is pulled out, the foam gasket should be replaced and there are a couple different ones so get the correct one the first time.
A leaking seal on the ball fall can spell disaster if the tank happens to fill and overflow. BTDT... Replaced our problematic Thetford toilet with a nice Dometic 310.
Why can't they put the sticker somewhere where you can easily see it?
Gil & Deb & Dougal the Springer Spaniel
Langley, BC
myredracer is offline   Reply With Quote
Old 06-27-2019, 11:59 AM   #4
PPST Wannabe
Then wed have nothing to complain about.
Think about it......would you want the label on the front of your fridge, stove, dishwasher, Televisions, washer, dryer, etc etc etc?
Bet youd be removing those real quick.
Ken and Terry
Old 06-27-2019, 12:01 PM   #5
Thank you both! I'll make a trip over to my trailer.
Old 06-27-2019, 12:57 PM   #6
Hi Rider's Avatar
Send a message via AIM to Hi Rider
Had the same problem. Problem solved. My dealer's service manager suggested periodically pour a couple of inches of mineral oil into the bowl. That lubricates the gasket. And when you flush, that also lubricates downstream gaskets. Also, I have found that if I let my RV set for a spell and the weather turns cold, the gasket shrinks just enough to drain the bowl.
Hi Rider
Jack and his dog, Annie
2016 Forester 2401W MBS pulling 2006 Jeep Wrangler
2017 - 189 Days and 8,857 Miles
2018 - 193 Days and 7,024 Miles
2019 - 173 Days and 8,109 Miles
Hi Rider is offline   Reply With Quote
Old 06-27-2019, 01:10 PM   #7
Witch Doctor's Avatar
Sometimes the flapper get out of wack, had that happen to me wouldn't hold water. Found a y- tube on it on how to reline it. Took care of mine....
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 06-27-2019, 01:32 PM   #8
Dometic suggests filling the bowl with hot tap water. It has worked for me. I had to do this twice after the camper sat all winter.
wvcampers is offline   Reply With Quote
Old 06-27-2019, 01:49 PM   #9
Take a toothbrush or any small brush and clean the gasket. Junk can get on the gasket and cause leakage. I also I purchased toilet gasket restorer from RV dealer and used.
I have never replaced one. Cleaning usually works. Mineral oil looks like a good idea. I might try that.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
txredfish is offline   Reply With Quote
Old 06-27-2019, 02:00 PM   #10
RudysWorld's Avatar
I used this and it worked:
https://www.thetford.com/product/toi...d-conditioner/
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 06-27-2019, 02:03 PM   #11
My toilet ball began to leak. I turned off the water, put on a rubber glove and wiped the seal with a folded toilet paper square to remove any gunk on it. It has not leaked since.
I will try the mineral oil suggestion to lubricate it.
Catalina 333RETS
Keystone Outback 23RS
Silverado 2500HD
Goldwing 1800GL
Wilco is offline   Reply With Quote
Old 06-27-2019, 02:04 PM   #12
The bowl gasket (at the flapper/ball) is easily removed and cleaned by turning off the water supply and holding the flush valve open. You can grab it and pull it out. (just don't drop it in the tank) A little silicone grease or plumbers grease will keep it working all season. Reinstall and you are good to go. Wear protective gloves if that kind of thing grosses you out but unless you wear them to wipe your butt, it really isn't any different.
Days Camped: '16=46 '17=30 '18=51 '19=53
Old 06-27-2019, 04:18 PM   #13
Also, our RV Dealer told us to be careful when you dump the 'blue stuff' in the toilet....try to keep it away from the gasket because it'll weaken the rubber. Our toilet isn't holding water right now, either. The flapper is cracked so they're replacing the toilet...thank goodness it's under warranty!
2019 Forest River Silverback 33iK
Ford F350 tow vehicle
SW Pennsylvania
Member Travel Resorts of America
Retired and adventurous!
Bbfish is offline   Reply With Quote
Old 06-27-2019, 04:26 PM   #14
PPST Wannabe
Darned shrinkage problems!!!!!!
Ken and Terry
Old 06-27-2019, 06:28 PM   #15
Originally Posted by RudysWorld View Post
x2
2017 FR3 28 DS
cariboo camper is offline   Reply With Quote
Old 06-27-2019, 06:56 PM   #16
We agree - this stuff works great for us. And we tried mineral oil, olive oil, plumbers grease, and industrial rubber lube, and none of them do the job of the Tetford stuff.
Bill & Kate, Stone Harbor, NJ
2014 Forest River Wildcat 272RLX Fifth Wheel
2018 Ford F-250 Super Duty XLT 6.2L Gas
Zeke (the Partipoodle) 4, Bailey (Std Poodle) 11 - both rescues
Cathcartww is offline   Reply With Quote
Old 08-05-2019, 09:02 PM   #17
You don't have to take out the whole toilet to fix the gasket on the flush ball on the Dometic 310. Just press on the lever to open the toilet ball and reach in and pull out the gasket. I bought a new one when we got our trailer and the instructions were on the package. Haven't needed to use it (6 years going on 7) yet and it hasn't leaked. Only thing we use is a little Dawn dish soap to clean the toilet and gasket. Pulling the toilet can be a pain and, if it's a Dometic, unnecessary. Thanks, for the tip about not pouring the "blue stuff" (presume some tank deodorizer) because it can ruin the gasket. I'll be sure to stay away from that, too.
ProfChuck is offline   Reply With Quote
gas
