Old 10-19-2011, 09:43 PM   #11
Double Tow
Hi folks, I haul this combo all the time, it tows quite well, the boat trailer does have brakes, it is no differant than hauling single, but when you operate this unit you must have experience dealing with over length trailers, I do have a CDL, which makes all the differance at times.
Don
Name:	fishing 2009 002.jpg
roadtech is offline   Reply With Quote
Old 10-21-2011, 05:15 PM   #12
JAYCO Representative
Wildcat Chris's Avatar
Talking
Don, that's quite a lot of toys in one picture!
Do you have any other pics? I'd love to see them...
Wildcat Chris is offline   Reply With Quote
Old 10-22-2011, 11:17 AM   #13
Anacortesians
Don't bring that rig to Washington. Even if it's legal where your vehicles are registered, you'll get pulled over and required to unhitch the aft-most item. I've seen one or two in the area with plates from the South East states, but they were lucky WSP hadn't spotted them yet. Just consider what it would do to your trip if you have to leave the boat unattended 3000 miles from home!
Frank and Eileen
No longer RVers or FR owners
Old 10-22-2011, 01:46 PM   #14
The days of traveling across a state without being stopped are fast coming to end with more checkpoints and roving stops being established by the Department of Homeland Secuirity and other agencies. It definitely will pay you to double check your documents to make sure numbers match the vehicles and everything is up to date before you leave home. By the time you see the checkpoint or roving stop, they have your records and at the stop it only takes glance for verification. If they should greet you by name at the stop, that will really make you a believer.
Stu (KQKM, AE) & Carol (Quilter)
2012 Wildcat 313RE
2009 Dodge Ram 3500 Cummins
Westernflyer is offline   Reply With Quote
Old 10-23-2011, 11:06 PM   #15
Here is one more for you Chris.
I have made a few changes since this photo, went to 16 inch rimes with LT rubber, replaced the shackles, bushings and all the bolts are now greasable.
Name:	june 2010 099 [1280x768].jpg
Old 10-24-2011, 03:00 PM   #16
Very cool!
