Old 01-20-2014, 06:13 AM   #11
Well the mystery has been solved. Took the unit out this weekend and discovered that of the three valves, the first one is the black tank and the next two are both grey. It was easy to tell once they were opened. The black tank valve and handle pull out further than the other two indicating a larger diameter pipe. As for the valve in the back. This appears to be for the rear bath and is a black tank also. This valve seems to be stuck open so back to the dealer we go for a repair. Also discovered that both sewer flush lines are leaking.a little. Had a great time trying the 5er out for the first time. Thanks for all the help.
seeemmiss is offline   Reply With Quote
