Old 09-24-2019, 07:13 AM   #1
GeezerPete
Vinyl Graphics need to be restuck
While my 2009 Wildcat was in storage the vinyl graphics became curled and started peeling on the side facing the sun. The cover blew off in a wind storm and exposed them to the sun.
Is there a good glue to use that will stick and hold these graphics on the fiberglass panels without harming their finish or lamination?
Oldtimer1029 is offline   Reply With Quote
Old 09-24-2019, 10:31 AM   #2
I've never found anything that can work. Being in So Cal we get a LOT of sun and most RV's 5 or more years old have peeling graphics. You've made it 10 years!
nayther is offline   Reply With Quote
Old 09-25-2019, 09:10 AM   #3
GeezerPete
Thank you for your response. Does anyone know where I can get replacement graphics for my Wildcat 5th wheel?
Old 09-25-2019, 09:16 AM   #4
Contact FR, they contract with a vinyl company or cut in house, maybe they still have some new old stock on hand. If that fails try a local vinyl printer/wrap company. Anyone that can do car wraps can make the vinyl, it's a large format printer with continuous feed. It won't be cheap.
Old 09-25-2019, 09:38 AM   #5
onetonford's Avatar
Search - WILDCAT
This is a company that seems to have some for Wildcats.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 09-25-2019, 09:45 AM   #6
Large graphics aren't easy to install , awkward to handle, especially if it folds onto itself. Spray the surface and graphic with water mixed with a drop of Dawn. This allows you to slide it around to proper position and then squeegee the water and bubbles out.
Ebay was my source in the past for discontinued RV graphics.
Removing the old graphic wont be easy either, hope it doesn't peel off in pieces.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 09-25-2019, 02:07 PM   #7
Smile
You might try a hair dryer when removing old graphics, it should loosen the glue.
Chuck& Shar
2018 2715VS
ncebeemer is offline   Reply With Quote
Old 09-26-2019, 04:48 AM   #8
DouglasReid's Avatar
First, FR does not stock graphics older than 2017.
One possible solution is to take a picture to a sign shop and they can duplicate it for you.
Then you will have to remove the old vinyl, the old adhesive and reapply the new ones.
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 09-26-2019, 01:25 PM   #9
GeezerPete
Thank you All
I want to thank all of you guys for responding to my inquiry. The hair dryer works, the link to graphics works and they can supply me with some. Finally, I did find a shop in my area who can print the others at a good price. Thanks again. Oldtimer1029
Old 09-26-2019, 10:54 PM   #10
We just ordered new decals for the nose of our FR 2013 Flagstaff Super Lite Classic 5th wheel. Don't believe everything you read! Research!!
Bill Roper is offline   Reply With Quote
Old 09-27-2019, 01:11 AM   #11
Well, billie, perhaps you can believe the FR rep who replied to me via email
"On 9/6/2019 1:22 PM, Sara Hankins wrote:
> Good afternoon Doug,
> Unfortunately, they are not. We are not able to get and graphics older the 2017. I have attached different options that would be available.
> If I can be of further assistance please feel free to contact me directly.
> Thank you and have a great day.
> Sara Hankins"
That is not to say they may not be available elsewhere, but NOT from FR.
