Originally Posted by TheWolfPaq82
Prints, Schematics, diagrams, do not exist in the RV world.
Brian Clemens has posted many for the Dynamax. But not all of us can spend $300k on a rig!
Some exist, but FR is usually mum with sharing them.
In this case, I’d pull the microwave and see if there’s a vent hole cut behind it. Depending on the style of microwave, it’s either a front plate that needs removed or screws from the top.
Once the space is open, I’d just drill a couple of exploratory holes with a small drill bit. You’ll find out quick if you hit framing. Keep it short so you don’t go thru to the outside until you’re ready.
