Old 07-19-2012, 03:38 PM   #1
Diesel 2500's Avatar
Waste valves
I have 2013 312 bhx and I have noticed that when opening my cap to drain tanks I have some fluids that come out when all my valves are closed. Any suggestions on easy fix or take back to dealer to have them fix it. Thx
Diesel 2500 is offline   Reply With Quote
Old 07-19-2012, 03:44 PM   #2
TURBS's Avatar
All four of mine weep a little as well.
I wouldn't be concerned till you get a foot full.
Old 07-19-2012, 03:45 PM   #3
Probably just residual fluid between the valves and the cover. I always put the slinky or an old coffee can under the cap when I loosen it.
Old 07-19-2012, 03:48 PM   #4
I hope it's just left over. Just afraid I might get some unwanted terds. Lol. I'll keep an eye on it. Thx
Old 07-19-2012, 03:51 PM   #5
Timex's Avatar
Don't dare let any of that stuff hit the ground or the Stink Police will arrest you for dumping waste water on the ground!
Timex is offline   Reply With Quote
Old 07-19-2012, 03:53 PM   #6
When you remove the cap, hold a can under it and pull the bottom of the cap out first. Angle the cap so it somewhat points away from you and don't pull it off more than about 1/8" at the bottom.
Old 07-19-2012, 04:44 PM   #7
TURBS's Avatar
Waste police?
Old 07-24-2012, 08:14 AM   #8
I have the exact same issue with mine.
Wildcat Blue is offline   Reply With Quote
Old 07-24-2012, 08:23 AM   #9
TURBS's Avatar
I think its the nature of the beast.
I have 4 holding tank valves and they all have a small amount of water that comes out when pulling the cap.
I don't think there's really a "fix"
Old 07-24-2012, 08:58 AM   #10
Mountainmanbob's Avatar
is it more that a half a cup
a half a cup or less
I would not worry about
anything more than that and it may be time to
change out the valve or valves
with the proper replacement valve
change out time should be prox 10 to15 min
of course that is if all goes smoothly
it does happen occasionally
Mountainman
Mountainmanbob is offline   Reply With Quote
Old 08-03-2012, 07:01 AM   #11
my 31ts valves seep also, cables from "T" handle to valve seem to be a littel week.
I installed a new 3 inch dump valve at the end of the drain pipe, spent arount $20.00 on all 3 parts needed, easy fix and works very well.
Denny in Los Lunas is offline   Reply With Quote
