Old 06-23-2014, 05:03 PM   #1
TSB
Water heater
I have an 01 wildcat. Heater will click and come on for just a few seconds then go off. Any help will be appreciated. Thanks
TSB is offline   Reply With Quote
Old 06-23-2014, 05:09 PM   #2
TURBS's Avatar
Air in the line?
Empty propane?
Popped opd valve?
If it has an electrical side does that work?
Old 06-23-2014, 05:23 PM   #3
TSB
Has gas. Worked yesterday so not sure how it would get air in the line. All electrical works. How would I check the opd valve?
Old 06-23-2014, 05:28 PM   #4
TURBS's Avatar
Turn off the gas valve on propane tank and slowly turn it back on.
Old 06-23-2014, 05:28 PM   #5
Ford Idaho's Avatar
Did you turn the gas off and then turn it back on between the working and non working time?
Old 06-23-2014, 05:31 PM   #6
markb5900's Avatar
Assuming you have remote start/light on your water heater. Does your light come on inside telling you there is a problem?
Mark B
2015 32 Foot Rockwood 8289WS 5th Wheel
2017 GMC 3/4 Ton TV
markb5900 is offline   Reply With Quote
Old 06-23-2014, 05:34 PM   #7
TSB
No we did not did not do anything in between. Yes the light will go off for a few seconds then come back on.
Old 07-24-2014, 11:11 PM   #8
jumbo131's Avatar
There has to be a thermacouple or flame sensor of some sort to detect the flame. It could be dirty or bad. Try rubbing it with some sandpaper to clean it. Happens all the time with central hvac heating systems. Works this time and on the next heating cycle nothing.
2011 F350 Dually 13,300 GVWR 3.73 ratio
2013 WildCat 344QB with outside kitchen
jumbo131 is offline   Reply With Quote
heater, water, water heater
