12-13-2017, 03:11 AM
Water Pump
On my 2018 fr262 RGX.... where is the water pump and is there any available storage space under the steps inside the "rig", Thanks in advance.
12-14-2017, 03:22 PM
the pump is usually near the water inlet to the trailer in the basement. On older models, the steps are indeed storage areas. I keep my shoes there.
12-14-2017, 08:43 PM
made new steps for mine and it has storage.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
12-15-2017, 01:35 AM
Water Pump
Thanks for the reply,,,,but I'm gonna have to sound like such a noob. When you say the basement you are speaking of the front storage area under the bedroom?
12-15-2017, 03:32 AM
Yes, that is correct. It should be within 3' of the outside inlet. This is so when you winterize and install the antifreeze, you fill up the hose from the inlet to the pump.
12-15-2017, 05:55 AM
Are there not at least 2 outside "Inlets", 1 for City Water and another for Fresh Water Tank,with a possible 3rd for "Anti-Freeze"? Youroo!!
12-15-2017, 07:56 AM
Yes 2, one for city water. 1 for tank fill. The antifreeze hook up will be hose at the pump hooked to a bypass valve. The Water Tank is not a hookup. Just a water fill opening.
12-15-2017, 08:06 AM
The 'basement' is referred to as ANY storage/access area under the main floor.
12-15-2017, 10:19 AM
On mine the water pump is in the basement hanging from the ceiling and no where near the water inlets. If you didn't get down on your knees you would never find it.
2011 25 RL Wildcat
12-16-2017, 02:22 AM
Thanks for all your help, Larry
12-16-2017, 05:48 AM
Did you find the pump?
12-20-2017, 12:21 AM
was trying to find out where to look. I now know where to start looking.
