Old 07-14-2013, 09:53 PM   #1
duradiesel's Avatar
Water Pump
I just got a 2012 Sterling & can't find the water pump? Also is there a filter in the water system any where? Thanks
duradiesel is offline   Reply With Quote
Old 07-14-2013, 10:07 PM   #2
Missing Link
cyclepuck's Avatar
Should be close to the fresh water tank and usually need to remove a panel in the cabinets to get to it.
2014 Puma 30-DBSS
2014 Ram 2500 Mega Cab 6.4L
cyclepuck is offline   Reply With Quote
Old 07-14-2013, 11:26 PM   #3
bikendan's Avatar
it would help if you posted which Wildcat model you have. they aren't always in the same place depending on the floorplan.
Equalizer WDH
Old 07-15-2013, 12:14 AM   #4
duradiesel's Avatar
It is a F32RL 2012 wildcat Sterling.
Old 07-15-2013, 08:13 AM   #5
Dave_Monica's Avatar
I'd suggest that you turn the pump on, open a faucet and follow your ear. It will be in the bottom of a cabinet behind a removable panel. If there's a filter. it'll probably be there also...you should plastic wrench that fits over the canister for removal.
Dave
Old 07-15-2013, 08:31 AM   #6
Oakman's Avatar
On my two previous Wildcats the pump was in the side front storage compartment. Like Dave said, put water in the fresh water tank,turn the pump and a water faucet on and follow your ear. Since you have a Sterling you probably have (or it did have) a tankless water heater which means you don't have a water filter.
Hopefully a fellow Wildcat owner will respond to this post soon.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
