Old 07-29-2018, 12:29 PM   #1
Water Pump Location
Help!
I think I burned up my water pump by leaving it on with the tank empty. I can turn it on, after I filled the tank, but it doesn't build pressure. Without tearing out everything to locate the pump, I would like some guidance locating the pump. I have a 2018 Wildcat 312 RL. Any help is greatly appreciated.
Dkdickerson is offline   Reply With Quote
Old 07-29-2018, 12:33 PM   #2
A32Deuce's Avatar
If you turn it on and it makes noise, follow the sound. May be hidden behind a panel in a compartment.
A32Deuce is offline   Reply With Quote
Old 07-29-2018, 12:36 PM   #3
You will most likely find your water pump near the point where you connect the city water hose, but hidden in an inside compartment. Look for a door that has three hinges on it. Remove the lone hinge where a latch would be more appropriate and you'll either find the water pump and filter or the water heater. If water heater, look for the other three hinged door
In my trailer the water pump is located behind one of these doors in the bathroom, below the tall closet door. My other door is hidden behind the pantry door at the bottom.
Floor plans vary but the clue will be where your city water inlet is on the outside. Close behind that will be the pump.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 07-29-2018, 03:47 PM   #4
Thanks all. I found it and the access looks pretty easy to get to.
Old 07-30-2018, 08:33 PM   #5
cavie's Avatar
The pump is easily rebuildable. kit on Amazon.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cat, location, pump, water, water pump
