Old 07-01-2015, 06:57 PM   #1
Water pump on a 2004 wildcat 5th wheel
where can I find the water pump . I bought the camper two weeks ago trying to figure everything out.. Also I have the camper plug into the house do I need to unplug it to check water pump and all the tanks.
GENE DAY is offline   Reply With Quote
Old 07-01-2015, 07:17 PM   #2
Just turn on the switch and open a faucet , you will be able to hear it run. It won't damage the pump to run it dry for a short time.
hillsdaletc is offline   Reply With Quote
Old 07-01-2015, 07:29 PM   #3
ok I found the pump and the switch by stove I turn it on and nothing. the slide will let in and out on battery the outside light will come on but nothing else will. try to check the tank and nothing on the panel comes on.
Old 07-01-2015, 09:03 PM   #4
Start with checking your fuses. If they're good you'll have to check for power at the pump, then the switch and so on. My pump is behind the utility center.
On another post you said the water tank won't drain. Is there water in the tank and are you using the right drain, not the low point drain or other tank drains?
GypsiesAtHeart2016 is offline   Reply With Quote
Old 07-02-2015, 02:18 PM   #5
Telstar's Avatar
Make sure you don't have the house water turned on. Pump won't turn on if house water is on.
Telstar is offline   Reply With Quote
Old 07-02-2015, 04:24 PM   #6
Could be a faulty pressure switch in the pump. Easy to change
Harkerr is offline   Reply With Quote
5th wheel, cat, pump, water, water pump, wheel, wildcat
