Old 08-21-2017, 03:16 PM   #1
Weighty issue
I have been reading the various threads regarding TV weights and 5er weights and am wondering if I am understanding correctly. I stopped at an unmanned weigh station a few weeks ago and got these readings. They all appear to be in KG, the red light on the scale says so but if I multiply by 2.2, those are weights I did not expect.
TV itself
Front - 4720
Rear - 3220 - - Gross 7940
TV attached
Front - 4720
Rear - 5440
Trailer - 9220 - - Gross 19380
As a teacher my signature was, “If you think education is expensive, try ignorance.”
As a novice Glamper, it still applies.
RobertDS is offline   Reply With Quote
Old 08-21-2017, 03:23 PM   #2
BandJCarm's Avatar
Either I don't understand (probable) or something is amiss. That gives you a 11,500 lb pin weight!!!
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 08-21-2017, 03:25 PM   #3
Yeah, me too.
If those weights were in pounds, I think things are close???
Old 08-21-2017, 03:27 PM   #4
key numbers are
So your trailer pin weight is 2220 and GVW is 10160. Loading of the truck and trailer will cause these number to change, of course.
2016 Prime Time Crusader 322RES
2016 Ford F250 6.7L Diesel, Crew, 4X4, SRW, 3.55, Platinum, Ride Rite air bags
Reese Elite 18K Hitch
Nights camped 2016=47 2017=67 2018=53
dennisewitte is offline   Reply With Quote
Old 08-21-2017, 03:27 PM   #5
Fulltime family RVer
Using TowingPlanner.com, here's what I come up with:
Truck Weight (hitched): 10,160
Truck Weight (truck only): 7,940
Camper Weight: 11,440
Pin Weight: 2,220
Pin Weight Percentage: 19.4 %
Looks like pounds to me.
What make/model camper and what truck?
Old 08-21-2017, 03:37 PM   #6
�� whew. I was hoping so but the little light by KG in each picture threw me.
TV - 2001 Ford F-350 Superduty
RV -2013 FR Sterling Wildcat 32RK
Old 08-21-2017, 03:48 PM   #7
Ok, I stopped panicking.
I just looked at the NADA spec sheet here http://www.nadaguides.com/Cars/2001/Ford/F350-Super-Duty-Pickup-1-Ton-V8/Crew-Cab-Lariat-4WD/Specs
And the TV seems good. I am looking for the GVW on the sticker on my 5er. Picture on iPhone too small. It seems it is slightly over 10,100. Specifics will follow.
Old 08-21-2017, 04:12 PM   #8
I just looked at the NADA spec sheet here 2001 Ford Super Duty F-350 SRW Crew Cab Lariat 4WD Specs and Performance | Engine, MPG, Transmission
Ok, now saving this picture to my iPhone where I can get to it at any time because I was way over what I remembered.
Old 08-21-2017, 04:19 PM   #9
The photo did not upload. This is frustrating.
The photo is from the side of the 5er stating the GVWR of 13670. The GAWR/PNBE for the axles is 6000 lbs front and rear.
I have so much to learn.
Old 08-21-2017, 04:21 PM   #10
I expect them to change but I will be more at ease after a couple of thousand miles towed and several dozen camping sessions.
Thank you.
Old 08-21-2017, 04:23 PM   #11
Thanks to all of you.
Old 08-21-2017, 07:06 PM   #12
Earlier, I tried to upload this picture from my Dropbox to this discussion. It would not upload so, I decided to try the Forum application. Click image for larger version
It appears to have worked.
Old 08-21-2017, 07:08 PM   #13
But why did it upload two?
weight
