Old 06-28-2014, 02:27 PM   #1
updhaul's Avatar
Wet Floor
Appreciate suggestions, we are near the end of our inaugural shakedown trip in our 2011 Wildcat 29bhs tt and have found the carpeted floor wet in the front bedroom (drivers or port side). No leakage in front storage, no rain on trip so water must come from plumbing or AC run-off. Just cleared gutters and double washered the city water connections to end leaks have pressure regulator 40lb. and have changed setup so ac runoff go to rear. Walls and ceiling are dry. No leakage seen underneath or interior or cargo bay in front of wet floor area....
updhaul is offline   Reply With Quote
Old 06-28-2014, 02:35 PM   #2
fonzie's Avatar
Do you have a black tank flusher connection? If yes have you used it and if yes was the carpet wet after?
Fonzie
Old 06-28-2014, 03:52 PM   #3
updhaul's Avatar
Good enough question to make me look underneath but all I found was the conventional two handle no special connection.
Old 07-24-2014, 09:44 PM   #4
jumbo131's Avatar
Is the wet spot on the floor by a bath tub? Sometimes the tub will get a small crack and leak.
2011 F350 Dually 13,300 GVWR 3.73 ratio
2013 WildCat 344QB with outside kitchen
jumbo131 is offline   Reply With Quote
Old 07-28-2014, 12:36 PM   #5
updhaul's Avatar
Thank you Jumbo131 for reply. This 29bhs tt has a bath on the other side and quite a distance from wet area. The wet area dried out with no more problems. Since the B&B water access is closest to problem I have found silicone on vent screen and cleared it and purchased but not yet installed extended gutter drains to keep water away from side window near wet area better. Waiting for a little help on them. Also replaced "good" brass pressure relief valve with cheap plastic camco with very good results when connecting and disconnecting. No further water problem on trip last week, still dry inside.
