Old 05-02-2016, 08:49 PM   #1
what specs do I torque my lugs to?
I have a 2003 Forest River Wildcat 5th wheel and want to torque my lugs to the correct specs. Does anyone know what these specs are and if there is a certain way to torque them? Thanks!
gr8white is offline   Reply With Quote
Old 05-02-2016, 09:24 PM   #2
2007 WildCat 32QBBS
05CrewDually's Avatar
For 1/2" stud 90 ftlb.
05CrewDually is offline   Reply With Quote
Old 06-01-2016, 01:33 PM   #3
Im still searching for the answer of what my lugs on my Wildcat need to be torqued to. Any ideas?
Old 06-01-2016, 03:58 PM   #4
2007 WildCat 32QBBS
My answer above isn't enough I guess. I have an 07 Wildcat with 6 lug.
Old 06-01-2016, 04:05 PM   #5
clr
05CrewDually Your answer looks fine and very complete to me. I have 9/16 studs so I have to torque to 120 ft lb.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 06-01-2016, 04:22 PM   #6
For Flagstaff alum wheels use the following: 90 lb/ft for a 1/2" stud is the bottom 120 lb/ft is top. I torque to 110 lb/ft.
File Type: pdf Flagstaff TT Alum Wheel torque specs.pdf (311.4 KB, 11 views)
Old 06-01-2016, 04:28 PM   #7
Ford Idaho's Avatar
Five lug 15" alloy wheels 110 lb/ft as per the sticker on the side.
Old 06-01-2016, 04:31 PM   #8
Im so sorry 05CrewDually. I just saw the diagram and didnt see that you typed the answer above it. My mistake. Im not sure if I have 1/2 inch lugs I will have to check!
Old 06-01-2016, 04:39 PM   #9
Here's a lug nut chart from etrailer:
https://www.etrailer.com/question-75604.html
2011 Traverse LT, 3.6L, FWD
