Old 03-25-2015, 08:44 PM   #11
We'll be picking up our 2014 293 REX in 2 weeks and towing it with a 2012 GMC 3500 HD CC SRW diesel long box. Can't wait!
GypsiesAtHeart2016 is offline   Reply With Quote
Old 04-14-2015, 01:36 PM   #12
bpdlk33 - no issues with it yet, just the normal stuff when you buy new from a dealer and they have never went through it. The sink was not even connected, found that out when I turned to pump on to dewinterize it. water everywhere in the kitchen and living areas. Hoses were not even under the sink. Dealer tried to say it was that way from the factory, but after looking at what they fixed, I am saying they scavenged the parts for another trailer. All other issues were minor fixes that I could do on the spot. I have found that the travel tool box I built comes in handy.
jkrise is offline   Reply With Quote
Old 04-14-2015, 09:16 PM   #13
Picked up the 293 this past weekend (4/9) and towed it about 200 miles. Nice easy tow & only a few minor issues with the cat.
Old 04-25-2015, 03:42 PM   #14
I have the same 6.2 and 3.73 setup in my 2011 F150 4x4 with the HD towing package and have no problem towing our 8,900 pound Wildcat fifth wheel. So far we have towed over 32,000 miles and the truck has 170,000 miles on it with no signs of mechanical problems. With the wind we get over 9 mpg. Against the wind we get around 7 mpg. It's just physics. It takes so much energy to move the rig down the road and you pay at the pump. We also drive highway speeds and don't avoid mountain passes. By the way, the new F150's don't offer the big 6.2 so the next truck will probably have to be a F 250. I have owned a
F 350 and F 250 in the past. This F150 does the job fine when well equipped.
Johnv is offline   Reply With Quote
Old 04-28-2015, 07:04 AM   #15
30+ year RV'er
Instead of installing air bags on our 2013 F-250, we added a helper spring (extra spring leaf) to the rear leaf spring set. Adds about 1 1/2 inches of support under load, which is perfect for our Wildcat 295RX. The cost was about 25-30% of adding air bags, and the ride is very good (not stiff, which can be hard on the 5th's frame).
Hyseas is offline   Reply With Quote
Old 04-28-2015, 06:21 PM   #16
Hyseas - what brand and model helper springs did you use? Just trying to figure out what my options are. Air bags are a little pricey. By the way I have the off-road package, so not sure if that affects the springs. New to some of this with a 5th wheel.
2015 Ford F-250 SuperCrew 6.7L w/Firestone Ride Rite Air Bags
2015 Forest River Wildcat Extra Lite 295RSX
Days Camped 2015 - 37
Old 05-02-2015, 06:34 AM   #17
30+ year RV'er
Helper Springs
I like the helper spring approach because they require no maintenance, allow full motion of the suspension, and take effect only when loaded (weight bearing).
Skyjacker makes helper springs that raise the vehicle 1 1/2" or compensates for 1,500 lbs. The 295RSX is about 1,600 lbs. hitch weight as I recall - so these worked well for our application:
Amazon.com: Skyjacker R3815 Softride Rear Add-A-Leaf Helper Spring - Pair: Automotive
There are other helper springs available from various manufacturers. Also, you might want to check with your Ford dealer. Ford offers a camper package that includes "rear auxiliary springs", which is otherwise known as a helper spring. Although the camper package is a factory option, your dealer may be able to add the rear auxiliary spring as an aftermarket option.
Hope this helps. Safe travels.
Old 05-02-2015, 12:38 PM   #18
5er_tom's Avatar
Hyseas,
Did you install them yourself? If so, how big a job was it? If not, where did you take it to have it done?
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2012 Ford F-250, 4x4, 6.7 Liter Diesel
5er_tom is offline   Reply With Quote
Old 05-03-2015, 07:30 AM   #19
30+ year RV'er
5er_tom,
I did install them myself - but I would not recommend it. The instructions said to remove the leaf spring pack, which was not realistic on my F-250. Instead, I left the springs attached to the frame and used heavy duty G-clamps to decompress, then compress the spring pack. Further, it required multiple jacks for the frame and axle, 3/4" drive socket set, and will likely require longer u-bolts to replace the stock ones.
In hindsight, I would suggest getting quotes from truck repair or truck performance shops. It's similar to the work to raise the truck frame for over-sized tires. Of course with the helper spring, it doesn't change the visual or handling characteristics of the truck. The helper spring sets run between $75 and $160, u-bolt sets $40-80, and I would guess labor to be around three hours ($150-200). So I would expect the total parts and labor to run between $300 and $450.
At the end of the day there is no question that it was worth it for us. I had tried the Timbren type approach first (these are rubber compression bumpers between the axle and the frame). Although it did make the truck ride level under the load of the 5th, it appeared to transfer every bump and pothole through the truck frame and to the 5th wheel hitch. I was worried about the increased stress on the 5th wheel frame, and was tired of cleaning up all our stuff that was pitched around inside the 5th. Hence by earlier comment about leaf spring range of motion. With the helper spring we are back to the full range of suspension, and our stuff is no longer being tossed around inside the 5th (compared to a frame to axle solution).
Old 05-03-2015, 03:55 PM   #20
5er_tom's Avatar
Okay. Thanks for the info. I'll pass on doing it myself. We have a good truck maintenance facility nearby. I'll go over and have a chat with them.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
tow vehicle
