Old 07-29-2014, 09:17 PM   #11
Mr. Dan's Avatar
Originally Posted by Rupkin2 View Post
With the trailers I have owned I have always found that the hand written items 1,2,3 etc match the fuses counting down, 1 being the top then count down.
Number 7 says pump, pull the fuse and try the pump. it probably won't work.
Number 10 says awning, pull that fuse and I would say the awning won't work either.
I could be wrong but give it a whirl.
Hopefully I explained this correctrly.
John
John, read OldCoot's post above. It's not what fuse is for what that I'm questioning, it's the 15 amp fuses in slots marked as 20's.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 56; booked = 6
Old 07-29-2014, 09:23 PM   #12
A 15a in a slot marked 20a should not bother you at all, it just means the circuit is not drawing over 15a and is not a problem. A problem is when the slot is marked 20a and it keeps blowing a 20a.
Old 07-29-2014, 09:23 PM   #13
Mr. Dan's Avatar
What's wrong with this pic?
Originally Posted by OldCoot View Post
Why even open the panel door? If it ain't broke, don't mess with it! If you can't see it, who cares?
Some of you wrote helpful comments a few days ago when I posted questions about blowing fuses on my front jack motor. I was told to replace fuses with resettable breakers and that if fuses on my 3 slides, my awning and my rear stabilizer jacks hadn't already blown, they would. I didn't see any problem in trying to locate 'em before they failed. How silly of me.
Old 07-29-2014, 09:30 PM   #14
TURBS's Avatar
I still recommend self resetting circuit breakers
"sabre owners united!"
turbs
Old 07-29-2014, 09:31 PM   #15
B47
Originally Posted by garbonz View Post
If it ain't broke, don't fix it. Seems like there are only undersized fuses in some of the circuits so if they don't blow, why worry.
You're speculating here. When you say "Seems like there are only undersized fuses ..." What if there are some "oversized" fuses (20 in a 15 circuit) installed and the 20 doesn't blow when something in the circuit goes bad? That's defeating the purpose of fuses.
I'm with the people here who would get both the correct fuse installed in the correct circuit and the diagram changed/replaced to be correct.
Old 07-29-2014, 09:32 PM   #16
Nothing wrong with it at all if that's what you want to do. I'm just not that inquisitive or energetic enough. I'll wait until something blows. Just too lazy! Heck, they had to beat my butt when I was hatched to make me breathe. Good thing it comes naturally or I'd probably quit that too and make a lot of folks a lot happier!
Old 07-29-2014, 09:35 PM   #17
Rupkin2's Avatar
Ok my mistake, missunderstood you message.............hmph thats odd, never had that happen to me before............
John
07- Classic 2500 LT CC 4x4 SB Duramax/Ally
13-320RLT Crusader TE
Reese 16K Kwik Slide/Prodigy brake contoller
Rupkin2 is offline   Reply With Quote
Old 07-29-2014, 09:38 PM   #18
B47
Kind of hard to understand that attitude coming from a man who worked on complex systems with very close tolerances and specific material requirements.
Old 07-29-2014, 09:45 PM   #19
Mr. Dan's Avatar
My trailer is new. I have not exercised each system to its max so I don't know what's broke and what ain't.
More importantly, I'm new here and I've seen the warning to those who are negative and have low post counts. I've tried to heed the warnings but if you guys saw my punch list and you knew how much trouble my dealer has had getting manufacturer support, you might understand why I'm studying things that haven't yet caught fire or exploded.
As I wrote above, I have a service appointment tomorrow and I want to rat out every issue I can before that visit because I don't want to take it back to the dealer before at least a month.
Worry less... camp more. Sounds nice.
Old 07-29-2014, 09:49 PM   #20
B47
Do the right thing and add this to your list for the dealer - someone did this for a reason. I just don't know if the reason is right or wrong.
