Old 07-29-2014, 09:58 PM   #21
dcheatwood's Avatar
Originally Posted by Evereddie View Post
You missed the bigger issue. One of the fuses is upside down. All that power flowing in the wrong direction. Watch out!
Now that was funny. I just thought he had a 51 amp fuse.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 07-29-2014, 10:02 PM   #22
Originally Posted by B47 View Post
Kind of hard to understand that attitude coming from a man who worked on complex systems with very close tolerances and specific material requirements.
Big difference between the two.
Old 07-29-2014, 10:05 PM   #23
B47
I guess so - if that was in my unit it would bug the hell out of me until it was corrected.
Different stokes ....
Old 07-29-2014, 10:22 PM   #24
Salt Shaker's Avatar
It would drive me nuts. I am anal about wiring. Items like this just makes you question what else was half assed. I had to rewire my battery compartment after I pulled into the driveway after picking mine up at the dealer and the landing gear wouldn't work. The negative was grounded by looping it around a sheet metal screw.
2014 Silverback 29RE, 2014 Ram 2500 CC 4x4 Hemi 6.4 auto w/ airbags, B&W Companion. Saltwater boats and rum like any good pirate.
Lose the 2nd and the rest will follow.
Salt Shaker is offline   Reply With Quote
Old 07-29-2014, 10:24 PM   #25
B47
X2
Old 07-29-2014, 11:37 PM   #26
I have to say that of my 31 fuses, none of them are 20 amps.
2014 Blue Ridge 3715BH <- Read the saga
2013 Sierra 3500HD Denali CCLB DRW 4x4 Duramax w/ Reese 20K
Camped: 2016=6, 2015=9, 2014=27
USN Retired (26 years), but not Retired retired
Home Port Orlando
Narboza is offline   Reply With Quote
Old 07-30-2014, 07:35 PM   #27
2014 XLR 27HFS
X2
I fix things on my new camper that ain't broke all the time.
If I actually KNEW something wasn't right, it would drive me nuts.
Dave & Audrey
dave961 is offline   Reply With Quote
Old 07-30-2014, 07:41 PM   #28
Easy fix, get (2 )20a fuses and replace the (2) 15a fuses. Easy fix. Problem solved. Oh don't forget to turn the one fuse over so the current won't flow backwards.
Old 07-30-2014, 08:01 PM   #29
Mr. Dan's Avatar
I'm at the dealership now... will sleep here tonight to have more punch list items fixed tomorrow. There should by three (3) 20 amp fuses - 5, 6, 10. All other Wildcats have 20s in these positions. We will not flip the upside down fuse... but Ha anyway.
The leak in my wardrobe slide appears to have been fixed, the microwave keypad failure has been demonstrated (awaiting FR response), leaking galley grey water valve has not been addressed. Kitchen slide cutting flooring has not been completely fixed although the following pic gives a clue to the 'underlying' issue.
After the flooring repairman leaves tomorrow afternoon, the service manager and I will decide when/if I'll have to bring back the trailer.
Thank you all for your support and encouragement!
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 07-31-2014, 06:24 PM   #30
Keisling's Avatar
Your fuses would drive me crazy. Of course, I'm the kind of guy that has to pull each one and document exactly what is on each circuit. I even had to replace the poorly written labels to satisfy my OCD.
-Dave
2014 Wildcat 312BHX
2015 RAM 2500 Mega Cab 6.7 Cummins Turbo Diesel
Keisling is offline   Reply With Quote
