07-29-2014, 08:17 PM
What's wrong with this pic?
I would prefer that these numbers match!
Which should be changed, the fuses or the descriptions or both??
07-29-2014, 08:30 PM
If this was my RV, I'll be very concerned as to why someone messed with the fuses and if the hand-written portion is correct. Either way, you may want to contact your dealer or manufacturer to determine exactly what amp fuse belongs to each circuit. Once that is accomplished, hopefully everything works safely keeping in mind that someone changed, swapped, removed, and / or switched them for a reason.
2010 Surveyor 294
2006 Ford E-350 Van 5.4
07-29-2014, 08:44 PM
Even tho' the descriptions say some should be 20a, as long as 15a is doing the job, why bother? If the 15a blows and it should be a 20a, just replace it with a 20a. Would not bother making a call or visit to a dealer on something like this.
Could be all the tech had handy were 15a fuses.
07-29-2014, 08:45 PM
Denver, CO
If it ain't broke, don't fix it. Seems like there are only undersized fuses in some of the circuits so if they don't blow, why worry.
2017 Fuse 23T
07-29-2014, 08:46 PM
This configuration IS from the factory. We're on our 1st trip in a new (2015) 5th wheel. I have an appointment with the dealership tomorrow afternoon so I'll add this to my growing punch list. I just found this "oddity" today.
07-29-2014, 08:56 PM
You missed the bigger issue. One of the fuses is upside down. All that power flowing in the wrong direction. Watch out!
07-29-2014, 09:00 PM
With the trailers I have owned I have always found that the hand written items 1,2,3 etc match the fuses counting down, 1 being the top then count down.
Number 7 says pump, pull the fuse and try the pump. it probably won't work.
Number 10 says awning, pull that fuse and I would say the awning won't work either.
I could be wrong but give it a whirl.
Hopefully I explained this correctrly.
John
07- Classic 2500 LT CC 4x4 SB Duramax/Ally
13-320RLT Crusader TE
Reese 16K Kwik Slide/Prodigy brake contoller
DW's 401(k) Plan
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
07-29-2014, 09:13 PM
Def an example of worry less camp more. But... That one upside down fuse would drive me nuts...
Sent from my iPad 6 using Forest River Forums
2017 Flagstaff FLT21DS
2011 Tundra Platinum, 5.7l, 2WD, Firestone bags...
07-29-2014, 09:16 PM
Why even open the panel door? If it ain't broke, don't mess with it! If you can't see it, who cares?
07-29-2014, 09:17 PM
John
John, read OldCoot's post above. It's not what fuse is for what that I'm questioning, it's the 15 amp fuses in slots marked as 20's.
07-29-2014, 09:23 PM
A 15a in a slot marked 20a should not bother you at all, it just means the circuit is not drawing over 15a and is not a problem. A problem is when the slot is marked 20a and it keeps blowing a 20a.
Some of you wrote helpful comments a few days ago when I posted questions about blowing fuses on my front jack motor. I was told to replace fuses with resettable breakers and that if fuses on my 3 slides, my awning and my rear stabilizer jacks hadn't already blown, they would. I didn't see any problem in trying to locate 'em before they failed. How silly of me.
07-29-2014, 09:30 PM
I still recommend self resetting circuit breakers
"sabre owners united!"
turbs
07-29-2014, 09:31 PM
You're speculating here. When you say "Seems like there are only undersized fuses ..." What if there are some "oversized" fuses (20 in a 15 circuit) installed and the 20 doesn't blow when something in the circuit goes bad? That's defeating the purpose of fuses.
I'm with the people here who would get both the correct fuse installed in the correct circuit and the diagram changed/replaced to be correct.
07-29-2014, 09:32 PM
Nothing wrong with it at all if that's what you want to do. I'm just not that inquisitive or energetic enough. I'll wait until something blows. Just too lazy! Heck, they had to beat my butt when I was hatched to make me breathe. Good thing it comes naturally or I'd probably quit that too and make a lot of folks a lot happier!
07-29-2014, 09:35 PM
Ok my mistake, missunderstood you message.............hmph thats odd, never had that happen to me before............
John
07-29-2014, 09:38 PM
Kind of hard to understand that attitude coming from a man who worked on complex systems with very close tolerances and specific material requirements.
07-29-2014, 09:45 PM
My trailer is new. I have not exercised each system to its max so I don't know what's broke and what ain't.
More importantly, I'm new here and I've seen the warning to those who are negative and have low post counts. I've tried to heed the warnings but if you guys saw my punch list and you knew how much trouble my dealer has had getting manufacturer support, you might understand why I'm studying things that haven't yet caught fire or exploded.
As I wrote above, I have a service appointment tomorrow and I want to rat out every issue I can before that visit because I don't want to take it back to the dealer before at least a month.
Worry less... camp more. Sounds nice.
07-29-2014, 09:49 PM
Do the right thing and add this to your list for the dealer - someone did this for a reason. I just don't know if the reason is right or wrong.
