Old 07-29-2014, 08:17 PM   #1
Mr. Dan's Avatar
What's wrong with this pic?
I would prefer that these numbers match!
Which should be changed, the fuses or the descriptions or both??
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 56; booked = 6
Old 07-29-2014, 08:30 PM   #2
If this was my RV, I'll be very concerned as to why someone messed with the fuses and if the hand-written portion is correct. Either way, you may want to contact your dealer or manufacturer to determine exactly what amp fuse belongs to each circuit. Once that is accomplished, hopefully everything works safely keeping in mind that someone changed, swapped, removed, and / or switched them for a reason.
2010 Surveyor 294
2006 Ford E-350 Van 5.4
surv294 is offline   Reply With Quote
Old 07-29-2014, 08:44 PM   #3
Even tho' the descriptions say some should be 20a, as long as 15a is doing the job, why bother? If the 15a blows and it should be a 20a, just replace it with a 20a. Would not bother making a call or visit to a dealer on something like this.
Could be all the tech had handy were 15a fuses.
Old 07-29-2014, 08:45 PM   #4
Denver, CO
garbonz's Avatar
If it ain't broke, don't fix it. Seems like there are only undersized fuses in some of the circuits so if they don't blow, why worry.
2017 Fuse 23T
Old 07-29-2014, 08:46 PM   #5
Mr. Dan's Avatar
This configuration IS from the factory. We're on our 1st trip in a new (2015) 5th wheel. I have an appointment with the dealership tomorrow afternoon so I'll add this to my growing punch list. I just found this "oddity" today.
Old 07-29-2014, 08:56 PM   #6
Evereddie's Avatar
You missed the bigger issue. One of the fuses is upside down. All that power flowing in the wrong direction. Watch out!
Evereddie is offline   Reply With Quote
Old 07-29-2014, 09:00 PM   #7
Rupkin2's Avatar
With the trailers I have owned I have always found that the hand written items 1,2,3 etc match the fuses counting down, 1 being the top then count down.
Number 7 says pump, pull the fuse and try the pump. it probably won't work.
Number 10 says awning, pull that fuse and I would say the awning won't work either.
I could be wrong but give it a whirl.
Hopefully I explained this correctrly.
John
07- Classic 2500 LT CC 4x4 SB Duramax/Ally
13-320RLT Crusader TE
Reese 16K Kwik Slide/Prodigy brake contoller
Rupkin2 is offline   Reply With Quote
Old 07-29-2014, 09:00 PM   #8
DaGrinch's Avatar
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 07-29-2014, 09:13 PM   #9
Orion's Avatar
Def an example of worry less camp more. But... That one upside down fuse would drive me nuts...
Sent from my iPad 6 using Forest River Forums
2017 Flagstaff FLT21DS
2011 Tundra Platinum, 5.7l, 2WD, Firestone bags...
Orion is online now   Reply With Quote
Old 07-29-2014, 09:16 PM   #10
Why even open the panel door? If it ain't broke, don't mess with it! If you can't see it, who cares?
