Old 01-17-2018, 07:15 PM   #1
Out of Order
Which tanks are heated??
All this winter talk has me wondering about my 2016 Wildcat Max T24RG. I have two (2) lighted switches near the kitchen sink that control the heated tanks. Living in CA I never thought to ask this and can't find any literature as to which two tanks are heated. Is it the gray and black holding tanks, the freshwater tank or all three? Thanks for any insight.
As a side note, I'm not sure adding heat to a black tank is a good idea!
Todt and Connie and Hank the Doodle
2016 Wildcat Maxx 24RG
2016 Ford F250 6.7L Diesel
todtc318 is offline   Reply With Quote
Old 01-17-2018, 07:20 PM   #2
It Freezes just like anything else! Youroo!!
Old 01-18-2018, 09:45 PM   #3
cavie's Avatar
it appears 2 out of 3. I'm gonna guess black and gray. Worst thing happens with the water you go thirsty! Gray would stop the trailer from flushing. Black would stop you from flushing.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 01-19-2018, 11:02 AM   #4
Switches are for gray and black water. Interestingly enough, most manufacturers either hide these switches somewhere, or never label them, or both. Leads to a lot of confusion.
2019 Tiffen Allegro Open Road 32SA
F53 / 24000# Chassis
2008 Jeep JKS
Ready Brute Elite / Blue Ox BP
High Desert is offline   Reply With Quote
Old 01-19-2018, 11:07 AM   #5
Mr. Dan's Avatar
It goes without saying... but I'm sure my unit is not like yours (and maybe like no other). I have one lighted switch that operates the tank heaters on all four (4) of my tanks ====> fresh, black, two grays [as far as I know... I've never metered each of them]. The light comes on if/when I turn it on whether or not it's cold enough for the heater pads to be activated. My switch is not labeled.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 01-19-2018, 11:19 AM   #6
I concur. Mine is even different as it is 4 tanks AND a small blanket on the sewer outlet port. My switch is lighted and the light comes on when turned on.
It is supposed to be thermostatically controlled but I've never measured the current draw either. Mine is labeled Tank Heater. (note singular when in fact it isn't)
Days Camped: '17=30 '18=51 '19=58 '20=14
Old 01-20-2018, 10:00 AM   #7
satdog01's Avatar
On my Flagstaff 832 I have one switch for three tanks, 2 grey, 1 black. On my unit, there is an electrical wire tie wrapped to the outlet pipe upstream of the dump valve. Nothing for fresh water except for drain. The few times we have dry camped, drain fresh water, turn on tank heaters no problems at 15 degrees. Carry bottled water for drinking and coffee. 88 - 94 cents a gallon depending where you buy it. Watch for sales on small bottled water as well, which we use most of the time. Keep a good stock of bottled water in outside kitchen so we always have cold drinking water.
2020 Georgetown 31L, Safe T steering, Onan Geny
2015 GMC TOAD w/Blue Ox tow plates
Pepper 🌶 Pomeranian rescue 327 nights as camping buddy
Days camped in FR, 2011-12 = 77, ‘13-14 = 98, ‘15 = 52
‘16 = 77, ‘17 = 81, ‘18 = 44, 19’ = 83, 2020 =
Retired :
satdog01 is offline   Reply With Quote
Old 01-20-2018, 10:30 AM   #8
One lighted switch marked on the main panel marked Tank Heater! This switch controls 4 Tank Pads,Fresh/2 Gray/Black and 2 sewer outlet valves pads plus two strait pipe runs pads! The Heat Pad MFG says liquid Must be in Tanks before using Pads,GOOD Luck with That! If it going to be below 32 F I turn ON the Pads! Youroo!!
tank
