Old 07-31-2015, 11:33 PM   #1
Wildcat 317RL and F-250
Hi, I'm looking at a 317RL. I currently have an F-150 eco boost but am looking to upgrade to an F-250. Are there others on the forum pulling this unit with an F-250? If yes, is it adaquet? Gasser or diesel? I'm leaning toward diesel. Gear ratio? Thanks for any input.
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 08-01-2015, 09:11 AM   #2
Learjet's Avatar
Yep pulling one see signature set-up.
My 2015 317RL full loaded for camping and full water:
Steer axle 3,900 (max front 4,250)
Drive axle 5,440 (max rear 6,100)
(7,000 lbs on F350 with same axle, I added Timbrens)
Trailer axles 9,720
Gross Vehicle weight 9,340 (10,000 rating)
Gross Combined weight 19,060
Pin weight @ 2,300
(2,460 minus truck hitch, truck not weighed with hitch installed)
Total trailer weight 12,020
-2017 Ram Cummins, Aisin DRW 3.73, 4x4
-2015 Wildcat 317RL
-B&W Companion , MorRyde pinbox
Learjet is offline   Reply With Quote
Old 08-01-2015, 11:33 AM   #3
jevanb's Avatar
my #`s are pretty close to learjets, but I tow with a diesel, if you live in a flat country a gas would be ok, we also have a 2014 F250 reg cab 4x long box 6.2 it is ok on the flats but put any weight on her or any hill and foot to the floor to climb
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 08-03-2015, 11:20 PM   #4
Thanks for the replies. We have now changed our mind and are looking at the Silverback 33IK... Will see where that goes
2016 Siverback 33IK
Old 08-27-2015, 07:23 PM   #5
Send a message via Yahoo to jallen02
My new (to me) 2012 F250SD Diesel
I have a 2014 Wildcat 317RL that is pulled by a 2012 F250SD Diesel and I have NO issues with either trailer or truck at this time. The Diesel is the only way to go you never know if you will get another trailer, the diesel will handle it.
jallen02 is offline   Reply With Quote
cat, wildcat
