Old 10-15-2016, 03:46 PM   #1
OzarkPreacher's Avatar
Wildcat 32WB
Looking at a 2017 Wildcat WB fiver. Anyone familiar with it? Looking for any information good or bad.
OzarkPreacher is offline   Reply With Quote
Old 10-17-2016, 10:50 PM   #2
guess no one is familiar with this unit. Appears to be a new floor plan for 2017. We pulled the trigger today and supposed to pick up on Saturday. Hoping we didn't make another mistake.
The journey is as important as the destination.
Old 01-19-2017, 09:05 PM   #3
How's the Wildcat 32WB
Now I'm looking at the Wildcat 32WB. Please tell me how it's working out for you? What kind of problems? And, what things that are working great. Any information would be great. Thanks.
SandyGA is offline   Reply With Quote
Old 01-20-2017, 10:50 PM   #4
We have used ours for about 20 nights so far. We have had several RV's over the years this being our second 5er. We have really enjoyed it. Love the fireplace feature. Wife loves the full size fridge and the island. We have the king size bed (this may be standard not sure). We did add a memory foam topper to the bed and it sleeps better than the one in our house. The oversize shower is great. I didn't like the little recliners it had in it so we talked the dealer into trading them out for some they had in their showroom. I'm 6'1" and 225 so little recliners don't work for me.
Our inverter went out during our walk thru and they replaced it with an upgraded one. They said the one from the factory was not big enough for the full size fridge so this might be something you would want to check out. We had a slight leak from the hot water tank due to a fitting that was not tightened properly. Other than that we like it better than any RV we have ever had.
It came with the slide topper rails installed and we are planning on adding the toppers this spring. Also as the electric auto level system. It is slower than ones we have had in the past but works perfectly and saves a lot of energy in set up. You literally hit the button and let it do its thing. Takes 3-4 minutes.
I would buy it again. Hope this helps you out.
Old 01-21-2017, 12:41 AM   #5
Thank you for the feedback. That's good to hear you have not had many problems. There are many things I like about this one. I'll spend some more time in it.
Old 02-01-2017, 07:31 PM   #6
Mountain Lovers
Thank you Ozarkpreacher for your great review of the 32WB...we have been looking at them and finally found one to look at in person yesterday..we are a little confused about that extra compartment in the large slide out behind the fire place...it has 2 plugs in it but if you would put a wine cooler or small fridge in there..it is on the wrong side of the camper...can't see the purpose of it...what do you use it for? There is also a big price difference from state to state so we have not decided where to buy yet...we really love the floorplan of this unit...we have a Flagstaff 5r now and would like a larger unit...do you by any chance know where the water filter is located? We were unable to find it! Thanks for your help! Any would be appreciated!
Fordcamper is offline   Reply With Quote
Old 02-01-2017, 08:24 PM   #7
If there is a water filter in ours I am unaware of it. I have had the basement panels down fixing the hot water tank leak and didn't see one in that area. Pretty sure there's not one under either of the sinks.
Yes, the odd storage bay with the electric outlets. I don't know what the purpose of that was intended for. I use that area to carry my cast iron cookware and burners. Also carry a couple of extra bag chairs in there.
The fireplace feature is nice on those cool evenings when you don't really need the heat on or if you want some additional heat. Works much better than I thought it would.
We put a small fridge and a wall mounted TV on a swingarm mount in the basement storage area since it was prewired for TV and had the electric outlet as well. Also put LED strip lights all the way around underneath for accent lighting and for better visibility at night when walking around outside. That's probably the best $80 I ever spent.
I have had the belly panel part way down as well and can tell you there is no insulation in there. I am planning on correcting that this spring. Will likely add a ceiling fan over the island at some point too. The bedroom air is loud but it blocks all outside noise so we actually decided we like it that way. Others may have a differing opinion on that.
Let me know if you find a water filter and where it is located.
Good luck. Not sure where you are located but we found the best deal near us at Colaw RV in Carthage, MO. I found a slightly better deal in south Texas but it wasn't worth the drive to go get it.
cat, wildcat
