Old 10-17-2011, 07:05 PM   #11
Oakman's Avatar
I’m surprised no one has mentioned a 6 gallon water heater for the dry camping package. A lot of water is wasted trying to get the water temperature right with the new tankless water heater on the Wildcats. I would also include a water filter system for the dry camping package.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 10-19-2011, 05:17 PM   #12
JAYCO Representative
Wildcat Chris's Avatar
Originally Posted by Oakman View Post
Iím surprised no one has mentioned a 6 gallon water heater for the dry camping package. A lot of water is wasted trying to get the water temperature right with the new tankless water heater on the Wildcats. I would also include a water filter system for the dry camping package.
Oakman, what's been your personal experience with our tankless water heater while dry camping?
Wildcat Chris is offline   Reply With Quote
Old 10-20-2011, 11:04 AM   #13
Oakman's Avatar
Chris, what's been your personal experience with dry camping?
My nephew owns a Wildcat Sterling and does mostly dry camping. We camped together just this past weekend and he demonstrated the system to me. He and his wife absolutely hate the tankless water heater. He wants to remove the tankless system and install a six gallon water heater in his Sterling.
Personally, I was more impressed with the six point leveling system on his Sterling and told him so. His response was that it was nice...when it worked properly. He's had the Sterling back to the dealer twice for the leveling system.
Bob and Joyce
ATU Local 788
Old 10-21-2011, 05:00 PM   #14
Oakman, the majority of my camping experience has been dry camping. From my first solo RV trips when I worked at Jayco in R&D during college to now, I'd say it's been 80% primitive set ups and camp sites.
That being said, I'm a fan of the tankless water heater for dry camping, although I know there's been a valid discussion about water use. Your, or rather, your nephew's usage and results may vary, but we've had good response to the system since going standard with it a year ago. There are literally thousands of Wildcat owners using it (and other brands picking it up now as well).
I'm sorry to hear of your nephew's troubles with the Level Up auto leveling system. This upgrade has been a huge benefit to our customers and has a very successful track record with us in terms of service. Since it was originally built for much larger and heavier RVs, the hydraulic system is quite powerful and well built. Please let me know if there's anything I can do to assist him!
Old 10-21-2011, 05:06 PM   #15
Getting back to the original topic, I'm wondering if there's any single item you'd consider VITAL or ESSENTIAL for dry camping. My thoughts immediately go to power (battery, generator, etc.) even though I'm really thinking this is somewhat opposite of the goal. Are bigger tank sizes really the #1 priority? I'm very interested in your thoughts...
p.s. Wildcat's exterior lighting kit is now LED, including the dual-mode docking lights...
Old 10-28-2011, 08:40 AM   #16
bhill's Avatar
Coming from a pop-up TC to hopefully a new Wildcat I have some suggestions as my TC was used mostly off the grid.
When it comes down to it, isn't it really all about power and water ? Anything you can do lessen power usage such as LED's would be a great start-- be sure to use the correct color of LED's some are very harsh on the eyes.
Considering using 6 volt batteries in a series to increase amp hours. Install solar panels to recharge the batteries and finally- increase the size or the fresh water tank-
bhill is offline   Reply With Quote
Old 10-28-2011, 08:49 AM   #17
Triguy's Avatar
Just out of curiosity.
Do fifth wheel trailers, in general, or Wildcat specifically provide batteries with new campers?
I have seen this talked about in this thread and I am a little confused because none of the campers I have had came with batteries from the factory; including my current Flagstaff.
Either the dealer popped in a cheap group 24 or I installed the batteries that I wanted - like the two T-145's I have now.
Is this a 5W thing?
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 10-28-2011, 10:23 AM   #18
Oakman's Avatar
It really is, as bhill states, all about power and water. While solar power is a great idea, it won’t work in all instances. When I dry camp, I’m always under a number of trees and solar doesn’t work well in the shade. It also doesn’t work well when you have a week of cloudy and/or rainy weather. Even George (Tioga and George Blog) carries a small Honda generator to recharge his batteries when the solar panels on the roof of his Class C can’t keep up.
My suggestion for dry camping would be a slide out tray or rack on the back of the trailer that would be sturdy enough to carry a generator, a gas can or two, and perhaps a Blue Tote. Sabre has a fold up bike rack option and Cougar has a slide out bike rack option on their fifth wheels that might work for that purpose. Something along those lines for a Wildcat would be great for a dry camping option.
Water is the other issue. A 60 gallon fresh water tank would be great. But the water tank should be designed with a slope to one side and a small pocket to the low side where the pickup tube would be. That way all of the fresh water in the tank could be used. In my Wildcat, when the water pump will no longer pick up water from the tank, there is still about three gallons of water left in it.
Triguy, yes fifth wheels do come with a battery installed, usually a cheap group 24 battery though. The breakaway cable on a fifth wheel requires a 12 volt battery in order to function. The breakaway cable activates the trailer brakes in case the trailer should disengage from the tow vehicle.
Bob and Joyce
ATU Local 788
Old 10-28-2011, 10:47 AM   #19
bikendan's Avatar
generally, the batteries on trailers are a dealer-installed item, not a factory item.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 10-28-2011, 12:08 PM   #20
Arrow 2" receiver hitch is standard
What about the 2" receiver hitch that's standard on the Wildcat? We thought rather than forcing a folding bike rack or slide out rack, we'd give consumers the option of any accessory that fits the receiver (bike racks, storage pods, generator mount, towing ball, etc.). The receiver is engineered and built into the frame with a tongue capacity of 300lbs. and a towing capacity of 3000lbs.
Here's some examples:
receiver bike rack - Google Search
receiver hitch cargo carrier - Google Search
receiver hitch generator carrier - Google Search
The Hitch Corner sells bike racks for trailer hitches
dry camping, extralite, sterling, wildcat, boondocking
