Old 07-24-2015, 01:00 PM   #1
wildcat max 2014 f313re back up camara wiring
Hi I have a 2014 wildcat max 5th wheel, I was told the wiring for back up camera and satellite was already installed from factory. Does any one know how to find the wires?
Also I cant seem to see how to bring the slides in manually if motors fail.
Trailer is awesome just spent 40 days traveling B.C. Alberta and Sask.
mustardjim is offline   Reply With Quote
Old 07-24-2015, 07:02 PM   #2
My Wildcat 327 ck already had the camera installed, it is near the top of the rear. I would look there. Good Luck
whj469 is offline   Reply With Quote
Old 07-25-2015, 06:09 PM   #3
If you do not have the back up camera installed, you should find a plug in the rear wall up about level with the red marker lights in the center. I can see the plug in mine and I assume that if you remove the plug, you find the wiring. I haven't actually tried that yet.
You should find the access hole for the manual crank for the dining room slide on the opposite side of the trailer in the lower flashing. The bedroom slide won't have a manual crank.
bruceatlam is offline   Reply With Quote
Old 07-25-2015, 06:14 PM   #4
Georgia Frog Rally 2018
aceinspp's Avatar
Also they may have installed just the mounting bracket up by the rear clearance lights. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
2014, cat, wildcat, wiring
