02-17-2015, 09:29 AM
#21
Originally Posted by ford1386
No mine is hydraulic
Then your ram is not extending it enough, might need to be blead off.
Coachmen M/H
Concord
2018 / 300 DSC
02-17-2015, 10:06 AM
#22
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
02-17-2015, 10:12 AM
#23
02-17-2015, 10:15 AM
#24
#25
Phat Phrog Stunt Crew
How does the inside of the slider look? Does the frame of the slider set equal distance all the way to the inside wall? This would be where the gasket seal snugs up. If there gaps along the wall this would be where to start.
2014 Wildcat 327ck
02-17-2015, 10:19 AM
#26
It is tight at the top against the wall to a 3/4" gap at the bottom both sides.
02-17-2015, 10:28 AM
#27
Sounds like the cylinder is not extending fully or your cylinder adjustment is off check and see if back cylinder nut has backed off and not pushing the slide out fully check the manual for this adjustment it shows how it should be. On page 16 of the PDF file.
2011 25 RL Wildcat
02-17-2015, 10:32 AM
#28
There is 4" between nuts but the nut that pushes out has a jam nut next to it, and real rusty so I doubt it backed loose. But if I wedge something between the nuts and the bracket when extending it just bends the bracket out and doesn't push the slide out anymore
02-17-2015, 10:36 AM
#29
Also may want to check under slide at seal where floor drops down for something caught in that area you might be able to see that better if you pull in slide slightly as it lifts the floor up to clear other floor possibly it has dragged the bottom seal into that area and is causing your problem.
2011 25 RL Wildcat
02-17-2015, 10:42 AM
#30
On mine in the corners were the carpet covers it is a plastic wear piece to let it lift over and drop into floor. Is it possible that the plastic is broken and is jamming the slide. I could see that as a possibility.
2011 25 RL Wildcat
02-17-2015, 10:50 AM
#31
Campfire Master
Check the rack and gear along each side on the bottom. There may be something jammed in the gear track preventing a full extension.
John
02-17-2015, 05:04 PM
#32
Mine has one hydraulic ram in the center and two slide rails
02-17-2015, 06:04 PM
#33
Not sure it's a lippert slide out, it doesn't look exactly like the pictures in the lippert manual onetonford posted. And the hydraulic pump says dewald on it
02-17-2015, 10:18 PM
#34
Did some more research it is a flush floor dewald hydraulic slide out.
02-17-2015, 10:36 PM
#35
Boy that is different than mine from what I have read on their pdf file it is kept square by two cables. I guess it is possibly a bad cable or pulley. I noticed it also has two rollers at the end of the slide that the slide lowers down into the floor so I would also think could be a bad roller. This is the manual I found for it. http://support.powergearus.com/techd...ideout_Sys.pdf
2011 25 RL Wildcat
02-18-2015, 11:03 PM
#36
I do not see any rollers in the manual what page did you see them
02-18-2015, 11:11 PM
#37
Sorry I saw them in another manual. Now I can't find it but it was the same brand.
2011 25 RL Wildcat
02-23-2015, 10:12 PM
#38
The slide is straight now, I adjusted the nuts on the hydraulic ram to push out about another inch and it sits level and against the wall now. But how did it get out of adjustment that far it's a steel slide frame with a hydraulic ram?????
02-24-2015, 10:05 AM
#39
Might want to check the tubing you said was flexing. One tube on mine did that and would allow it to jump a tooth or two.
Herk7779 gave me lippert field fix. Push the stud on top of the rail down and grind a slot in a washer to keep it tight. Should be able to find on forum. Was summer of last year. I made over$300 for 2 service calls without getting it fixed. There is a lot of good information here.
